The turbo oil feed line is leaking a large amount of oil at the engine block connection. It apprears to be leaking where the nut screws onto the fitting. The nut is tight. Is there a gasket or o-ring that may need replacing? I haven't taken it apart, in case, I need to have a replacement gasket handy. Or is the line just failing from age? It has always leaked there a bit, like a drop or two once in a while. But lately, a large amount of oil has been leaking.
