What is the maximum boost, a SBC/90 degree V6 can withstand?? I thought we were pretty safe up till near 30lbs of boost (I don't know if I'd go much over 25) until the head gasket/bottom end let go. Were better off than the Buick guys, we have 5 bolts around each cylinder they only have 4. Check out the October issue of Hot Rod, they put a Vortech supercharger on the V6 they built last month. They got an impressive 500hp out of it, but.. lost the head gasket at 12 pounds of boost??? WTF?? It had fairly low 9.1:1 compression. They said "You really can't blame it: we were cramming 12 psi into the poor engine" WHAT? I run that on much on our stock '92 ty. The last paragraph states that "One solution would be to add copper head gaskets and O-ring wire" Is that really necessary, for 12 psi?? I don't think so!! Mabye they should have used better head gaskets.
Your Opinions??
Thx Brad :-?
Your Opinions??
Thx Brad :-?
