Re: My Lightweight Syclone
Maybe down the road this will help in this weight loss quest.......But I'm nearing the end of plugging a stock SY hood for IvankoBarbell for a full CF bolt-on race hood. Should come in near 8-13lbs braced with full substructure.
Next is a Sy 2" cowl hood for CF bolt-on.(donar in stock)
Then Sy full CF tailgate with full substructure ( weight yet unknown, aiming at useful/sitting weight of 12lbs.)(race 4-6 lbs)Donar part in stock.
I've got a prepped Drivers fender,need a good Passenger in order to begin those for CF.
PPRESS donated a full SY bed that I could use but the passenger side is toast,the inside etc. is great.( big project,but doable for max weight loss,$$$ ??)
Bed cover with new SY type design is in the works for CF too. :tup:
I also have set aside several Interior bits that I felt would be attractive if done.
All of these projects are designed and engineered for Resin Infusion Vacuum ( NOT open mold wet lay-up which is resin rich,brittle and heavy)
Infusion built into my molds allows for the most perfect Resin to cloth weight ratios and strengths. But the tooling and consumables aren't inexpensive so please ...no comments on "how much'??
...it is what it is....I can't help that.
CF is justifiable for some ....Fiberglass for others.
Cheers,Vinny
