VIPERRACING
Guys, I have a ultimate 3 bar chip tune & the truck stalls after about 20 minutes of driving or after it heats up & will not start unless idle is turned up or if I open & controll the start up by my foot or unless it sits long enough to cool down. But here's the kicker, When I swap out the map sensor with a 1 bar it will start up & idle totally fine. So I ordered a new 3 bar map sensor because I figured that was the problem but its doing the same thing after it heats up as before. So to double check I swapped in the 1 bar after the truck wouldnt start and it started right up and once again held idle perfectly & then I swapped it back out to the 3 bar and once again no start unless I open the throttle blades by foot pedal or by turning up the idle with the throttle stop screw. I have already swapped out the iac with a new one thinking that was the problem first before messing around with the map sensors. The truck has a mild build(4-bolt forged short block, l-35's, 412, pte 52, 50lb inj, ultimate 50 chip). Thanks again for any and all help.
