kessler
Re: Nitrous as a turbo lag assistant...?
I second that, Unless you plan on using a Stand alone system to adjust for fuel and or Timming i wouldnt do this. Heres the deal, Parish is already running 1055 HP with out N20 he uses a hell of alot of Meth for boost and like i said N20 is only used to spool the turbos on his truck, And to tell the truth he wouldnt use it at all if he could get a looser Stall Converter.
I am setting my Ty up with a Mega Squirt to run fuel and have also come up with a way to use Coil Packs and a crank sensor so i can Adjust timming on the fly with changing boost and Meth. This is all from Experiance with how this stuff works on similar set ups of how you plan on running it.
So dont take what we say on here as mean or harsh but we are helping with what we know. And even thoe you say just a 30 shot or so figure it like this, With out a set up thats able to change fuel or timming for the N20 you very seriously run the risk of Blowing that motor very quick. So do what you want but be very carefull on how you set it up, A basic computer chip will not be able to control what you want with that set up. So good luck with what your doing.
turbodig said:The preload on the drivetrain is a good thing... it'll break fewer parts than hitting a loose drivetrain with power.
With a 20g, and a decent converter, you don't need to help spoolup. I can spool much faster than the tires will allow on a 4-5 psi launch.
Dry spray on a chip that isn't set up to add fuel for it, even for a few seconds, will likely cause reliability issues.
My .02
