Syclone#2960
What ever it takes!!
Re: NO FUEL FROM INJECTORS...no start
The motor has about 2500 miles. We added another ground from behind the driver side head to frame 0/1 gauge. The rest look very good.
did you try another dist? I believe the ign module controls injector pulse
Do our trucks need oil pressure to fire the injectors like some of the other GM cars out there? Maybe a bad oil pressure switch. What about that fuel pump again maybe you have pressure but not volume. If it was any ignition part it would not fire when using starting fluid. What about the injector drivers on the computer? Did you swap out the computer yet?
How many miles on the motor? I wonder if you could have jumped a tooth or two on the timing chain? It's a long shot.....if you heard that sizzling up by the distributor that's a clue.... are all of your grounds good (left front of intake manifold, rear of left cylinder head, battery ground)??
