Power steering pully being a PIA
BRASCO
Got to take it off and its being a ****!!!!!!!!!!!! Tried two different pullers and no good considering cutting it in two? Its a aftermarket aluminum one . Any ideas before its go time?
bdydrpds10
Yes I drive a Typhoon.
Re: Power steering pully being a PIA
I need to know this too... Because my stupid alternator bracket broke taking my dead alternator off.
Now I need to replace the bracket.
Richard Le
Have you tried using a torch to heat up the area around the hole in the pulley to expand the hole a little?
hardtailcfl
I had this same problem. Seems to be pretty common. I ended up just taking the entire pump/pulley assembly out and replacing it....It just wasn't worth my time to fight with it anymore.
New pump - around $60
Pulley - $15
Just an idea :2cents:
BRASCO
I used heat, two different type of pully pullers and way to much time. Im going to cut it off im thinking! or just replace the whole thing, great idea time is money and i lost my ass with this thing!
Richard Le
as far a a aftermarket pulley it may be tough, i have a march pulley on my v-8 s-10 and i don't think it has the notches in the pulley like the stocker
The March power steering pulley has three threaded holes for a special puller to thread into. The question is who makes a puller that utilizes those three holes?
BRASCO
I used the puller for the pully with the three holes and its on so good it ripped the threads out of the pully.
