PropShaft
tfink660
Anyone have a spare prop shaft laying around they want to sell. im not trying to spend 300 for one.. ill start hitting yards if i dont find anything here i know cardone has one for 2 something..
Throws
Re: PropShaft
Find a Olds Bravada, better shaft that the stocker but at junkyard prices. And it's rebuildable when you need to.
-P
Throws
Re: PropShaft
91-94 Olds Bravada.
Olds Bravada:
Stock Ty (on top)
tfink660
Re: PropShaft
they have all diffrent ones from them years will it matter??? Some say AWD others say 4x4 Will it really matter?
Throws
Re: PropShaft
All Bravadas are AWD (just like us!), so the 1st Gen Bravada is the best option for a cheap stock replacement.
-P
tfink660
Re: PropShaft
ok ill let you know.. Im gonna check with that site as they have a ton of them from 75 to 100 In A Grade Condition. Would you happen to know if it makes a diffrence if i had to use a specific one or will it not matter? because some say 4x4 and others say AWD please let me know your input.
tfink660
Re: PropShaft
thanks throws alot of them for like 75.00 just have to drive like 80 miles to pick up no big deal to save all that cash.
Throws
Re: PropShaft
I think the ones that say 4x4 are the yards not knowing the intricacies of the cars they part out. Make sure you select "Front Driveshaft" for the part.
-P
fivetodrive
CRISPY
Re: PropShaft
Be sure to get a propshaft safety loop when you put one in. The bravada propshaft still has the double cardan joint that can be problematic in many case when it breaks it takes out the transmission case...
Throws
Re: PropShaft
Can you eliminate that fault by upgrading the u-joints with better Spicer/Dana units?
-P
fivetodrive
CRISPY
Re: PropShaft
I don't know, it is a better unit than ours without having the rubber boot but I am not sure what breaks. I will have to look at some old posts.
