Ok, well im in the process of putting together a new engine for my Ty, seeing as the stock engine puked(broken crank) and the stock turbo has 163K miles and while it still is working good it has some shaft play and is needing to be rebuilt, but id like to upgrade to something bigger for somemore power.
Anyways i found this PTE 60-1 on ebay seems like a decent deal so far, polished comp, 4in inlet anyways, can i just swap out the turbine housing for a SyTy specific exhaust housing and then all ill need is the PTE or RPM DP kit?
http://cgi.ebay.com/ebaymotors/PRECISION-PT60-1-GARRETT-TURBO-TURBOCHARGER-TURBONETICS_W0QQitemZ200022033284QQihZ010QQcategoryZ33742QQrdZ1QQcmdZViewItem
Thanks for the help
Or is there anyway that this turbo will bolt to the stock manifolds, and then i can just modify the stock DP to bolt to this turbo and use it that way??? That would be ideal for me at this point in time.
Thanks for the help
