Question for people using a minigate
typhoon-crazy
installed the minigate today. just running a vac line from the turbo to the fitting on the side of the minigate. when i go wot i get about 12-13 psi. is this what i should be seing as base boost or is something not right? Thanks
ghettosled
SYTY SUPERSTORE
it has a 10psi spring, so thats probably close on a stock turbo setup. Depending on your turbo setup, exhaust, motor, etc you will see a +/- variation. If you need a smaller spring, they make 5psi ones which would probably give you 7-8psi.
12-13 psi at WOT sounds like a good base.
