fisherbody86
First off, this is my first post on SyTy (I've been a thirdgen.org member for years) and also new to tuning. I'm trying to put together a turbo 2.8L for my 88 Fiero, and I'm going to run the 749 ECM for obvious reasons. I have TunerPro, the BBZB 1580 .bin, and the $58 definition file. But where do you change the cylinder displacement? I don't see it anywhere in the def file. Also, could I just basically copy the spark and fuel tables from the stock 88 .bin and plug them in to the BBZB .bin for a starting point. Then just tweak them and play with the boost multiplier tables? I'm not sure that I'm using the correct terminology here, but hopefully you guys understand my questions.
P.S. I won't even THINK of actually burning any chips until I have a better understanding of what I'm doing. I'm reading the P4 doc and searching the chipping posts, and I'm learning a lot, but it's hard at first.
