typhoon-crazy
is running over 50psi fuel pressure bad?? and i know i should look on a scanner at my O2 volts, but when trying to get the fuel pressure right about what number should i look for on the O2 volts??
typhoon-crazy said:is running over 50psi fuel pressure bad?? and i know i should look on a scanner at my O2 volts, but when trying to get the fuel pressure right about what number should i look for on the O2 volts??
Thanks, had to refresh old GM Training memory. This means 'power enrichment' mode would be more rich if BLM were at 123-125 (during cruise). Did I get that right? Would that be too much with a stock chip and no mods?Sy769 said:SyTy's have two cells- open and closed throttle.
The BLM is only updated during cruise. If the ECM is adding fuel (BLM above 128) then it will take that into account during WOT. If it is below 128 it will not subtract any fuel out.
Are you looking at the O2 trends for this or at BLM? Did BLM eventually correct for the higher pressure setting?Sy769 said:My truck runs very rich on the stock calibration at 50 psi.
TyMeUp said:Yes, boost pressure is applied to the vacuum line of the fuel pressure regulator to assist the spring that controls base fuel pressure. This gives you a one psi FP 'increase' for each one psi of boost pressure.
When at idle and part-throttle, vacuum is applied to the fuel pressure regulator to work against the spring that controls base fuel pressure. This gives you one psi FP 'decrease' for every two inches Hg of vacuum.
The objective of this 'automatic' pressure adjustment is to keep the pressure drop at the tips of the injectors constant under all operating conditions. If not adjusted, intake vacuum would 'pull' extra fuel from the injectors causing the engine to run rich and boost pressure in the intake would 'push' back on the injectors, causing the engine to run lean. This is, of course, opposite of how you want it to work.
