Radiator hose
Typhoon #2131
SAVE THE TA-TAS
Ok guy's I need help once again. For the second time in 2 weeks I have lost the upper radiator hose due to the alternator getting into it when I get on it hard. This morning it did it to me at work when I jumped on it hard for a guy that works next door. I'm thinking wrong hose? Can anyone give me the part number to the right hose that is supposed to be on it.
Thanks.
wheels
Re: Radiator hose
Sytyauthority lists these #'s
Goodyear #61312
Napa #NBH-8684
I got one last week looking up a 91 Sonoma, and worked fine. Lower is specific, but the upper shouldn't be. You still have the stock fan shroud? It has a little arm that keeps the hose from getting too close to the alternator.
gkrcr882
SyTyless......for now!
Re: Radiator hose
Can also try an engine tie-down to limit the movement or even pre-load the mounts. Even stock mounts in good condition can move quite a bit, there is a lot of torque being transmitted.
Beavis
Still plays with trucks
Re: Radiator hose
Easy way to tell if Motor Mount is bad. Open the hood, sit in truck, do a light and easy brake torque (one foot on brake and LIGHTLY tap the gas). You can see the intake between the hood and cowl. If the motor moves more than a 1/2 inch it's bad. :2cents:
Re: Radiator hose
They are brand new. I just put a fresh motor in it 1000 miles ago.
At autozone, if you ask for a 91 Syclone upper hose, it is incorrect. You have to ask them for a 91 Sonoma 4.3 and it comes up correct.
This is how it should look:
If yours does look like that, I would go back and check your motor mounts even though they are "fresh". Bad mounts are the #1 cause of alternators eating the hose...there is no other reason.
wildphil
I Love My Ty's
Re: Radiator hose
If your alt is getting into the upper hose then the engine is moving. Have someone watch the engine. Then hold the brake down so the truck wont roll and then give it a little throttle.If the engine lifts then the motor mount is loose or broken.
wheels
Re: Radiator hose
Autozone's and Advance auto site shows the same part # for S-15 vs Sy. NAPA's site is down to triple check
E71420
Re: Radiator hose
E71420
Maybe AZ finally updated their database then. Do they still show CR43TS for the recommended plug? I dont know how many times I notified system admin of that error when I was a manager there in a previous life.
wheels
Re: Radiator hose
Of course they do. I mentioned it a couple times too, but it didnt seem to help things.
Although Advance Auto's site is no better for plugs
Showing 229 products for your “1991 GMC Syclone” :roll:
Typhoon #2131
SAVE THE TA-TAS
Re: Radiator hose
Goodyear #61312
Napa #NBH-8684
Yeah I still have it and it is in the arm but not very well. thanks for the part #'s
Typhoon #2131
SAVE THE TA-TAS
Re: Radiator hose
Yeah my hose looks lust like that one. Is there a different motor mount for the typhoon and a regular S-10 blazer?
Foot Performance
Re: Radiator hose
My factory mounts did not move enough to get into my radiator hose so I would think somthing is not right there but I still use the tie down method to keep the engine from moving its alot easier to install than new mounts.
