Treymen
Re: Radiator Upgrade
I like it.....
I'm using a stripped down stock-style radiator (no oil cooler, no trans cooler, and no heater ports) with a Flex-A-Lite 220 electric fan setup (dual 12" fans in one enclosure). With a 160dF t-stat I see no more than 164 degF no matter what I do (and I live in South GA). With a 140dF t-stat I see no more than 149dF under the same conditions. My entire cooling system consists of:
- Aforementioned Radiator
- Flex-A-Lite 220 Electric Fans (wired to ECM control)
- No shrouds
- 160 or 140 degF thermostat
- New stock water pump
- Stock upper/lower coolant hoses
- A/C Delete (so that condensor isn't in front of radiator)
- Tranny Cooler relocated to rear (so that it isn't in front of radiator)
Basically, a radiator, low temp t-stat, dual 12" electric fans, and nothing blocking airflow except the grill. Never a moments trouble in 5 years (and counting) and I drive it daily in 100+ degF GA heat and have even done a few 30 min sessions @ Roebling Road Road Course.
Take it FWIW.
Hood
I like it.....
