Replacement turbo question
Ntrain2k
Any opinions on how a Precision SC6152S would perform on the 4.3?
0.63 AR exhaust, 0.70 Cold side. It has a GT35R wheel.
TIA.
Darin
Re: Replacement turbo question
It would perform well. With the smaller .63 housing it'll spool great. Might want a little bit of a stall on it (say 2400?) but I would give it a go on the stocker and see how it goes.
Ntrain2k
Thanks!
It's going on a '99 blazer that I'm using the sy/ty manifolds on. 2114 intake converted to MPFI and 50 lb/hr injectors.
You might want bigger injectors (60#), that turbo will be able to max out those injectors.
Ntrain2k
I'm not going max effort on it. 350 hp or so will make me happy for now.
350hp will be a cake walk. I have a later factory balance shaft block bottom with Vortec and custom cam. My truck is making 450+hp at 14psi. Even if I had stock cam and Vortec heads, I don't think it would be that difficult to make 500hp+ with higher boost levels and the 2114 intake has better air flow distribution (and I suspect air flow) than the factory SyTy intake manifold. The biggest question is if the factory short block will take it.
Ntrain2k
Down the road I might build a motor for it. If so I'll find out what the factory bottom end will take, lol.
