V6QUICK
Used with less than 100 miles
RPM 700R4 TRANSMISSION LEVEL 7
*Media blast transmission case
*RPM Level V 3-4 clutch pack
*RPM reinforced sunshell with collar and bearing
*Heavy Duty double caged 29 element sprag
* low roller clutch
*Billet 4th gear servo
*Transgo HD-2 shift kit
*Corvette Servo
*Wide 2-4 band
*Updated aluminum accumulator piston
*Bushing kit
*New GM valve body spacer plate
*Seal & gasket kit
*GM Filter
*RPM Spec clutch and band clearances
*RPM sleeved input drum
*Billet over-run piston
*GM 5 pinion planetary gearsets - front and rear
*NEW Extra WIDE Heavy Duty double caged 29 element sprag
*300m Billet output shaft
*700r4 low roller clutch
*Billet 2nd gear servo
*300M Billet Input shaft
*Billet Pump Rotor
*Billet Forward Piston
*2-3 HD Apply Valve
*Deep Aluminum pan
*Micropolished Internal
Optional upgrades include:
$350.00 - Cryogenic Processing
$250.00 - Powder Coat Case
Level VII $3995.00 plus $450.00 core cost.
Total cost $5045.00
You can have it for $3500
* low roller clutch
*Corvette Servo
*Wide 2-4 band
*Bushing kit
*Seal & gasket kit
*GM Filter
*Billet Pump Rotor
*2-3 HD Apply Valve
*Deep Aluminum pan
Total cost $5045.00
