Re: Running lean all the time
I realize the wb02 is not the root cause of be issue but its not working.
I would first verify the fuel pressure with the truck running and driving. The fuel pressure should be approx 43psi for a stock chip and it will rise to 58-59 psi (rise 1 psi per # of boost.). I know you say it has a new walbro but their are many knock offs and even real walbro had some failures.
Next I would check to make sure the IC pump is working and pumping properly. High intake temps will cause knock.
