Scanmaster for SyTy
I've done some searching the last few days to see why one of these hasn't been done up for the SyTy crowd. As a crossover from the Buick GN scene, I have used the Scanmaster on the Buick for almost 10 years and found it to be almost a requirement to have. Now with the Typhoon, I find that I really need something like this for just regular day to day driving.
I know the guys that invented and make the Scanmaster and have beta tested alot of different electronic devices they have made and everything they do works perfectly. I have sent an email to Bob Bailey to see just how doable this is. I have sent him ECM wiring diagrams, serial data among other things for him to review. This is a very good possiblity and a product that once you have it, you will wonder what you did without it. From my searching this has come up from time to time and just sorta fizzles out for whatever reason. I'm not going to let this happen here, this device is too important not to have and I will persue this even if it winds up being a one off for me :D
For those of you not familiar with the Scanmaster, it is a self contained scan tool that is no bigger that a pack of 100 length pack of smokes. It can be mounted on top of the dash for easy viewing or wherever you prefer. It displays the scan data from the aldl port from o2 and knock retard readings to BLM and INT, just a whole slew of things. Best thing is you don't have to lug around a laptop with this. Now this doesn't replace the Datamaster or TunerPro but what it does is allow you to monitor your goings-on in the ECM at all times at a nice easy glance at the dispaly. Here is a link to the Scanmaster manual for the GN just to get familiar with just what it does http://www.fullthrottletech.com/showthread.php?t=1488
I do not know what the price will be on this if it happens. The prices for the current Scanmasters vary from $249-$300, so if I had to guess it would be within that range. I would say the more that is SERIOUSLY interested the closer the price would be to $250, but I just don't know. I also know from the searching that I have done that if there were 30 people or more to do this then they would go full steam ahead. I also know that in the past when they were approached to do this they had other projects going that demanded most of their time, like the Translator Pro and Powerlogger. Those products have already been released and I'm hoping that they will have enough time to put to this if we can get the interest up.
If you are truly interested in this then post up here, the more serious interest the better the chance this happens. I know alot of Buick guys have crossed over to the SyTy and I know that they would be onboard from using the Scanmaster in the past. So go ahead and post up, check out the link above and I promise you that if this happens you will not regret getting one and you will wonder what you did without it. Thanks!! ( and sorry so long ;) )
Here is a link to the Scanmaster for the 1G DSM/Stealth and 3000GTVR4 http://www.fullthrottletech.com/showthread.php?t=2093
The above would be more of the capibilities the Scanmaster would do for the SyTy since the SyTy ECM is much, MUCH better than the GN's ECM. Thanks!!!!!!
Re: Scanmaster for SyTy
midnightbluS10 said:
SyTy'ers use Datamaster mostly.
http://www.ttspowersystems.com/DataMaster.html
Seems they've been working on scanmaster for the SyTy's for about 5 years now.
http://www.syty.net/forums/showthread.php?t=2885&highlight=scanmaster
Yeah, that's what I found in my searching, hopefully it will go this time.
Keep in mind that the Scanmaster will not replace the Datamaster. The Scanmaster does not require the use of a laptop for monitoring, but will display data on the screen at all times so you can keep an eye on things at all times without having to have a laptop in the vehicle. The ability to see knock retard at all times would make it worth it. If you can see the knock happening, you can get out of the gas instead of just going on the fly without knoing what it's doing.
This has been tried several times, in fact I remember sending him info ~5yrs ago. Many guys would like to see this happen and hardware wise I "THINK" he just needs to change the software to read our info.
They would sell if he can make it happen, good luck as this is only about the 10th time I have seen someone try to get it made for us maybe this time you have closer connections.
Raist103
Engine Killer, iPhone Killer, Lawnmower Killer
yup like said above this has been tired many times and many would buy, i would pay now if it was to happen for a preorder. problem is, it will not happen. unless they have changed the way they run things over there. mass production only for them and the maybe 1500-2000 units that would sell tops i dont see them doing it.
James Thomas
"NO CLASS"
Well I'd be in for $300 or less but I also don't think it will happen...... or it already would have. Why can't we just take one, (ahhheem) volunteer THE CODE $59 CREW / maybe Craig Moates and see if it can be done?
Hell I bet they can do it better for our trucks anyway, plus it's obvious that "those" guys aren't interested in our truck for what ever reason? I remember a discusson (more than 5 yrs.) years and years ago and notting ever happened then either. I wanna say like 00' or so. This has been up several times and they just never move on it (again for what ever reason) and I agree with Jeff, I think it would sell!
Disclaimer: Only joking about the "volunteer" thing. I know it's the new year and every one is busy.
_________
James
MRKING
New Parts for Old Trucks
Tunerpro rt will datalog , emulate , and has many dfi standalone type options , why is that not good enough ? Oh yeah , its also free .
You are right, if you keep a laptop in the truck all the time. Some people do, which is fine. This is another option, a different option that will allow you to monitor what's going at all times in a nice and small unit. Like I said before, the Scanmaster will not replace the loggers or tuners everyone uses. When I had my GN, I had the Scanmaster which as there at all times but for fine tuning and such I had a few other logging programs I used with my laptop when I needed them. But for monitoring o2's and knock and the like for everyday driving, the Scanmaster was invaluable.
Just another side note, this not Ramchargers. Mike Licht and Bob Bailey are Full Throttle Speed which used to be Modern Musclecar. Their sales, service and customer support are second to none. If this happens, there will be no problem with the mass production end. They have been the innovating force for the GN for years.
The email conversion I had today with Bob said that and I quote "A couple guys have asked, but it has never been enough to get a project
going. Its a fair amount of work to just sell a couple units
." Which shows they are willing, but we have to be too.
I know these guys well and I think I might have enough pull to get this to really happen. Maybe for them to see our interest, perhaps a pre-order or half down now and the rest when they are ready to ship might be the way to go. I just don't know. But if anyone is truly interested in this, then post here. If we can get enough willing participants listed, I'll send Bob a link to this thread and maybe when they see how many we have wanting this they will go ahead with it.
supersports10
could we get it to fit in a 2 1/16 gauge like the one for the obd2 that's called the "interceptor"???
James Thomas
"NO CLASS"
Well if done correctly I.E. matches our interior or is in a 2 1/16 gauge setup like the Interceptor that supersports10 mentioned above (this will give many mounting options and woul be what I would like to see!)...... I'd be in. After seeing a basic description of what it will do and how it will do it and drawing or mockup of the unit... I'd go a half down pre order.
NEXT IN LINE?
_________
James
The casing is black, the info lights up in red. Sounds good already eh :) I doubt they will do a pod, as mentioned earlier the Scanmaster is about the size of a pack of 100 length cigarettes.
Any info you can't find on chip and the ecm communication I can get. I have access to just about any info they need so that shouldn't be a problem.
Heck I know of people who have ecm's running on the bench to test that would probably test out things.
Raist103
like i said i am in and will put half down. dont care if it is box or gauge, i like the box better since i have enough gauges around anyways.
That sounds great!! I sent him alot of various things for this, I'd say he has most everything already from previous attempts but I'll see if there is anything more specific he needs.
I believe if we could get around 40 committed people, and by committed I mean maybe a half down now and half when shipped pre-order, it could put this on more of a faster track to getting done. I'm really excited about this!!
boost
i have one in my buick and would love to have one for the ty. bob bailey and fullthrottle are good people. half down let me know when .
Alright, let's go ahead get a short list going and hopefully we'll be adding alot of folks to it :tup: I'm only going to put the guys on the list that said they want one. If you would want to be in on this just post your intentions and I'll add you to the list. I'm hoping that 30 will be the magic number. Thanks!!
1) TurboDonnie
2) Ross L
3) Bad Ass Black Trucks
4) Raist103
5) James Thomas
6) boost
7) lavaman
8) 2221
9)
10)
11)
12)
13)
14)
15)
16)
17)
18)
19
20)
21)
22)
23)
24)
25)
26)
27)
28)
29)
30)
You might post a price.
I know of a non list guy that might still be interested.
