ScannerPro released
93 TY 2185
Re: ScannerPro released
ashman said:
Dig, since you're on the "forefront" of the innovations...care to elaborate?
In the Works/Possible Future Features:
  • Alky/NOS pump/fuel control - Cut boost if Fuel Pressure is low.
  • Fuel Pressure Input into ECM and output into ALDL
  • EGT Input into ECM and output into ALDL
  • Security
  • 2 stage rev limiter, launch control
  • Knock output to a Guage (actually see how many Degrees knock you are getting) - In testing
  • Highway Mode (better gas mileage when cruising, configureable)
  • More WBo2 Control (When in PE mode, Open/Closed). Allow Full use of the F29_AFR when in Boost (Above 100 kPa) - We are still hashing out algorithm
  • Expanded NVRAM support (will need it for More Learn cells for the WBo2 Fueling Algorithim)
http://www.syty.net/forums/showthread.php?t=39955
