I bought TIMKEN 513124 wheel hub/bearings from RockAuto. They came with the ABS sensor sealed inside the bearing assembly. When I took apart my truck for installation, it had the sensor mounted to the dust shield with reluctor wheel on the hub. If I remove the old sensor from the dust shield the new TIMKENs will bolt up and the new harness will plug in like normal. But I would like to know if the new style sensor in the TIMKEN has a signal compatible with the old sensor. I have not been able to find info on interchangeability. Has anyone done this?
