Couger1968
Dazed and Confused
Re: Setting timing question
I swapped out my ignition module back to my factory one. The timing is perfect again. Ac Delco D1943A must not the correct one for our trucks. Does anyone know what would be the correct one is if I had to replace it?
Sorry for a hijack, but I see a similar thing. Is this why when I set timing with the wire disconnected at 0 then reconnect and check with a hand held scanner and an adjustable timing light at idle there is 4 or 5 degree difference. Example timing on the scanner said 29 and it is actually 33 with the light. Should I set it actual timing or keep setting it with the wire disconnected and 0. I have a msd box and knock off distributor, with a ac Delco D1943A module.
