Setup for Innovative MSBC - 1 Multi Stage Boost Controller
For those with the Innovative MSBC - 1 Multi Stage Boost Controller - how are you setting up your units in terms of stages and ramp speeds?
ghettosled
SYTY SUPERSTORE
set ramp to default which is the fastest spool up. If you are having traction problems maybe you can back it down a tad. As for the stages, I prefer a 12v switch so you just hit the button whenever you need more boost. If you want launch boost, just tap into your brake light signal so when you power brake it only goes to whatever boost you set it to..
hope that helps
