GAShan
The ABS has never worked on the Ty. Now the pedal is real soft and if you sit at a light and hold down the pedal it slowly goes to the floor. You have to pump it or eventually the truck starts to creep. Swapped out the master (twice) yesterday and it still does it. Bled the brakes really well a few times. No leaks in the rear wheel cylinders, no brake fluid leaks anywhere. Only thing left that could be the problem is the ABS unit. Any ideas? I'm ordering an ABS bypass kit from Hood but would prefer to keep the ABS unit in the truck if I can because everything else in the truck is stock.
