Re: 1992 Prototype Syclone - $12,500 FIRM
Here's the RPO info from comp nine/gm when I ran it...
Vehicle: PICKUP
Year: 1991
Build Date: 1990-08-17
Found 946,297 vehicles matching your year and model in our database.
RPO Description Matches
UA1 BATTERY,HEAVY DUTY HVY DUTY BAT(UA1)
116,227
UP8 RADIO,PROVISIONS FOR STEREO INSTRUMENTATION STEREO RDO PROVISIONS(UP8)
657,810
UX1 RADIO,AM/FM STEREO,WEATHER,CASSETTE,EQUALIZER,ETR,INCLUDES CLOCK STEREO AM/FM W/CASS & EQLZR(UX1)
90,411
U26 LAMP,INTERIOR,ENGINE COMPARTMENT COURTESY E/CMPT CTSY LP(U26)
489,888
U27 LAMP,INTERIOR,INSTRUMENT PANEL COMPARTMENT COURTESY I/P COMPT LP(U27)
600,856
U28 LAMP,INTERIOR,ASH TRAY COURTESY ASH TRAY CTSY LP(U28)
600,856
U52 CLUSTER,INSTRUMENT(ELECTRONIC) ELEK GA CSTR(U52)
32,201
U73 ANTENNA,FIXED FIXED ANT(U73)
715,130
VF6 BUMPER,REAR STEP RR STEP BPR(VF6)
693,690
VXS Unk. 939,562
V02 RADIATOR,HEAVY DUTY,INCLUDES HEAVY DUTY TRANSMISSION OIL COOLER HVY DUTY RAD & TRANS OIL CLR(V02)
79,818
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
940,939
XEB TIRE FRONT P235/75R15/N OWL R/PE ST TL OOR (9590910) TIRE(XEB)
78,712
YC2 TAHOE/SIERRA CLASSIC/SLE(LUXURY) TAHOE/SIERRA CLASSIC/SLE(YC2)
501,099
YD3 AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE FRT AXLE(YD3)
946,297
YD5 SPRING,FRONT(BASE EQUIPMENT) FRT SPRING(YD5)
938,492
YEB TIRE P235/75R15 (STEEL BELTED) TBLS RADIAL OOR W/LTRS TIRE(YEB)
78,712
ZEB TIRE SPARE P235/75R15/N WOL R/PE ST TL OOR (9590910) SPARE TIRE(ZEB)
78,712
ZM5 SHIELD PACKAGE,UNDERBODY U/B SHLD PKG(ZM5)
42,462
ZM6 OFF ROAD SUSPENSION PACKAGE OFF ROAD SUSP PKG(ZM6)
27,235
ZM7 PACKAGE,INTERMITTENT WIPER AND TILT WHEEL PULSE WPR & TILT WHL(ZM7)
367,688
ZQ2 DRIVER CONVENIENCE PACKAGE DRVR CONVENIENCE PKG(ZQ2)
86,435
ZY1 COLOR COMBINATION SOLID SOLID PAINT COMBO(ZY1)
691,915
Z88 GMC TRUCK G M C(Z88)
258,549
1SX PACKAGE- OPTION 22 (1SX)
45,636
1SZ PACKAGE OPTION- (1SZ)
759,121
47E TRIM COMBINATION,CLOTH,DARK RED (47E)
56,187
47I INTERIOR TRIM,DARK RED (47I)
257,523
6CA SPRING COMPTR SELECT FRT LH SUSP(6CA)
24,740
7CA SPRING COMPTR SELECT FRT RH SUSP(7CA)
24,740
72U EXTERIOR COLOR,PRIMARY (72U)
EXTERIOR COLOR,PRIMARY,MEDIUM GARNET RED METALLIC (72U)
171,387
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
86,435
AV5 FRONT HIGH BACK BUCKET SEAT FRT HIGH BACK BKT ST(AV5)
233,411
A28 WINDOW,SLIDING GLASS,REAR WINDOW SLIDING R/WDO(A28)
320,672
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
86,435
B32 COVERING,FLOOR MATS,FRONT AUXILIARY FRT AUX FLR MATS(B32)
527,697
B96 ORNAMENTATION,EXTERIOR,WHEEL OPENING MOLDING(BRIGHT) WHL OPG MLDG(B96)
ORNAMENTATION,EXTERIOR,WHEEL OPENING MOLDING(USED WITH VALUE LEADER WV9) WHL OPG MLDG(B96)
450,292
CTF INTERIM DESIGN CHANGE,REFER TO VEHICLE OPTION LABEL FOR VERIFICATION INTERIM DESIGN CHANGE(CTF)
582,327
C6F GVW RATING(5150 LBS) 5150 LB GVWR(C6F)
45,881
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
582,849
DC4 MIRROR,INSIDE,REARVIEW TILT,DUAL READING LAMP I/S DUAL READING LP RR VIEW MIR(DC4)
489,888
D34 MIRROR,INSIDE,SUNSHADE S/S MIR(D34)
MIRROR,INSIDE,SUNSHADE(USED WITH BERETTA GT PKG Z21) S/S MIR(D34)
567,738
D44 MIRROR,OUTSIDE,BELOW EYELINE(PAINTED) O/S PAINTED MIR(D44)
MIRROR,OUTSIDE,BELOW EYELINE(PAINTED)(9.5 X 6) O/S PAINTED MIR(D44)
669,180
D55 CONSOLE,FRONT COMPARTMENT FLOOR F/CMPT FLR CNSL(D55)
CONSOLE,FRONT COMPARTMENT FLOOR(USED WITH BERETTA GT PKG Z21) F/CMPT FLR CNSL(D55)
200,923
E63 BODY EQUIPMENT,FLEETSIDE PICKUP BOX FLEETSIDE PUBX(E63)
946,297
FF4 ARM,TORSION BAR,SPRING ADJUST,LH TORS BAR SPR ADJ ARM(FF4)
98,838
FF5 ARM,TORSION BAR,SPRING ADJUST,RH TORS BAR SPR ADJ ARM(FF5)
98,838
GMC PLANT CODE PONTIAC, MI, GM T&B PONTIAC,MI GM T&B ASSEMBLY PLANT(GMC)
205,462
GU6 AXLE,REAR,3.42 RATIO 3.42R(GU6)
403,824
G51 SPRING,SPECIAL HEAVY DUTY REAR HVY DUTY RR SPR(G51)
146,405
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
50,753
JM3 BRAKE BOOSTER,DOUBLE DIAPHRAGM HIGH FLOW(240MM) DBL DIAPH BOOS(JM3)
408,537
KC4 COOLING SYSTEM,ENGINE OIL ENG OIL CLG(KC4)
COOLING SYSTEM,ENGINE OIL(EXPORT-IRAQ) KC4(EXPORT IRAQ)
42,479
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
232,653
LB4 ENGINE,(4.3L),V6 90 DEG GAS TBI, DIRECT SALES ONLY 4.3 (LB4)
ENGINE,(4.3Z),V6,EFI 4.3Z(LB4)
408,537
MD8 TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8)
381,470
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0)
TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION)(MD8) A/TRANS PROVISIONS(MX0)
381,470
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)
865,089
N40 STEERING,HYDRAULIC(NON-VARIABLE) NON-VARIABLE P/S(N40)
693,988
N90 WHEEL,15X7(CAST ALUMINUM) AL WHL(N90)
87,303
QEB TIRE ALL P235/75R15/N WOL R/PE ST TL OOR TIRE(QEB)
78,712
SLM Unk. 828,328
TR9 LAMP GROUP,COURTESY LP GRP(TR9)
489,888
T63 WARNING SYSTEM,HEADLAMPS ON ALARM HDLP ON ALARM(T63)
600,856
Rarity...
There are 6 1991 PICKUP vehicles (0.001%) matching your exact options list. There are 6 (0.001%) with at least as many options.
