Specialist
are my solid engine mounts going to effect my knock sensor and i have the poly transmission mount can i go with a solid tranny mount
I have solid motor mounts on my truck and they have no effect on the knock sensor. I have heard not to use solid mounts on the trans. But I have no experience with them.
I have solid motor mounts & you MUST !! run A solid Trans mount or you will break or ( crack the bell housing). DO NOT use just the rubber trans mount. I welded mind solid. I can do yours also, just send it to me & pay for S&H here & back to you.
AJ
Where did you hear about needing to run a solid trans mount with solid motor mounts? Just curious more than anything, as I was always under the impression that you should not run a solid trans mount with solid motor mounts. This was because of the flex in the frame needed to have some give in the trans mount or you could break the trans housing.
I personally have run solid motor mounts on my trucks for years with poly trans mounts and never had any problems.
John
