Syborg Twin Turbo
Syborg Twin Turbo
Current Project Sponsors
www.compfab.com
www.autometer.com
www.airbagparts.com
www.stainlessworks.net
www.billetspecialties.com
www.precisionbrakescompany.com
www.sportmachines.com
www.mirradographics.com
Good Morning All,
Okay i plan to post picks and build info and keep updating this thread till the truck is complete.
http://www.sportmachines.com/gallery/Sonoma-Gt-0334
Stage One -Dissasembly
http://www.sportmachines.com/gallery/stage-one
Removal of Bed
Removal of Front Clip
Removal of Cab
Remove and Discards part not wanted on Frame
Sandblast Frame
Repair Damage Body Mounts
Paint Frame
Stage Two - Wheels & Tires
http://www.sportmachines.com/gallery/wheels-tires
18 x 8 SLG20 Soft Lip Wheel225/45 18 BFG KDW-220 x 10 SLG20 Soft Lip Wheel295/45 20 BFG KDW-2
Stage Three - Rear Suspension
http://www.sportmachines.com/gallery/sogt0334rs
Special Thanks - Comp Fab, Dustin Performance, Wilwood, Currie Enterprise
Moroso Wheels Studs
Wilwood Disk Brakes
Aluminum 9" Ford - Aluminum Third Member
Custom 4-Bar w/Anti-Roll Bar
Afco Coil Over Shocks - ???lbs Spring
Poly Suspension Stops
Stage Four - Chassis
http://www.sportmachines.com/gallery/chassis
Special Thanks - Comp Fab, RK Kustoms, Bad Ass Bowtie, Village Auto
Frame Boxing & Chassis Modifications
Tubular Frame Cross Bracing
Tubular Drive Shaft Loop
Tubular Trans Mount
Poly Trans Mount
Rear Tie Down
Frame Pad
Frame Pad Modifications
Motor Mounts
Front Tie Down
Stage Five - Front Suspension
http://www.sportmachines.com/gallery/sogt0334fs
Special Thanks - Comp Fab, Dustin Perfromance, Village Auto, Pro-Tec Powder Coating, Hi Speed Welding, Air Ride, Hotchkiss, Summit Racing, John Waller, Rockford Racecraft
Shock Wave - Air Ride Upper & Lower Control ArmBell Tech SpindleWheels StudsLug Nuts MetricHalf Shaft RetainersHalf Shaft Bolts Half Shaft NutsBOLT 2 REQ - Upper Control ArmTORQUE LOCKNUT A/R BOLT 2 REQ - Lower Control ArmTORQUE LOCKNUT A/R Moog Idler ArmMoog Center LinkMoog Tie Rod EndsBear TrackersBellTech Sway BarAGR Steering Box20" SBE Plated Polished Shaft3/4" -36 x 1" -48 U-Joint Polished3/4" -36 x 3/4" -36 U-Joint Polished
Stage Six - Fuel Delivery System
http://www.sportmachines.com/gallery/fueldeliv
Special Thanks - Hi Speed Welding, Race Proven Motors
Fuel Cell with Baffles
Fuel Sending Unit
Roll Over Shut off Valve
Fuel Cell Tank Holder
"Y" Block w/Hobbs Switch
Weldon 150gph efi pump (-12in -10out)
SX Billet EFI Fuel Filter, slimline -10 inlets
Tubular Cross Member Mount
Weldon Dial A Flow "1400 Pump Controller"
Fuel Line & Ends
Fuel Line Cooler
AN8 Fuel Return Line & Ends
Weldon Fuel Pressure Regulator
Stage Seven - Paint & Body - Cab
Special Thanks - Comp Fab, Rockford Racecraft, Peter Humblias, Valley Welding
http://www.sportmachines.com/gallery/p-bcab
Roll Cage w/Side Brace
Cab - Media Blasted
Cab - Etched and Expoy Primer
Rocker Panel Repaired - Body Work
Body Mounts Repaired
Firewall Smoothed
HEX BOLT-CAB/RADIATOR MOUNT
FLAT WASHER A/R
RETAINER
SHIM-CAB MOUNT A/R
Poly Body Bushings
SCREW A/R
C.R. Laurence - Back Glass
COWL SCREEN 1 REQ
Windshield Shaded
Windshield Trim-Black
Exterior Rubber Kit
Drivers Side Door
Passenger Side Door
DOOR WINDOW SEAL-OUTER-LH
DOOR WINDOW SEAL-OUTER-RH
DOOR WINDOW SEAL-INNER 2 REQ
Cal Vue Power Signal Mirrors
Door Lock Gaskets
Stage Eight - Brakes
http://www.sportmachines.com/gallery/sogt0334eng-trans
Wilwood Pedal Dual MasterWilwood 7/8" MasterWilwood 1" MasterWilwood Remote AdjustWilwood 14.1" Front BrakesWilwood 14.1" Rear Brakes
Alot more to Come.
www.compfab.com
www.autometer.com
www.airbagparts.com
Good Morning All,
Removal of Bed
Removal of Cab
Sandblast Frame
Paint Frame
Moroso Wheels Studs
Wilwood Disk Brakes
Tubular Trans Mount
Poly Trans Mount
Rear Tie Down
Frame Pad
Motor Mounts
Front Tie Down
Fuel Sending Unit
Fuel Line & Ends
Fuel Line Cooler
Cab - Media Blasted
Firewall Smoothed
FLAT WASHER A/R
RETAINER
SHIM-CAB MOUNT A/R
Poly Body Bushings
SCREW A/R
COWL SCREEN 1 REQ
Windshield Shaded
Exterior Rubber Kit
Drivers Side Door
Passenger Side Door
Door Lock Gaskets
Alot more to Come.
