Sonoma GT 519 - the rebuild saga (picture intense)
SY2455
70's Veteran
Re: Sonoma GT 519 - the rebuild saga (picture intense)
jjorgensen52 said:
Also, I could've sworn the muncie (M500 / MV500) was in the later trucks and had a single piece case....
You are right the Muncie is a single piece case. I was in a wrecking yard 2 weeks ago and there was a 1989 S-10 blazer with the 4.3 manual trans. This trans was a muncie.
Doing some reseach I found out that the T-5 was only use in the Astro and Safari vans with the 4.3, never in a S-10 pickup. That why I mention the bellhousing thing to you. I still check everything when I go to the wrecking yard, looking for the right bellhousing. This is my problem as well.:rant:
Maybe I should just do a T-56 as it would be easier. Just my :2cents: .
jjorgensen52
NHSTE - I'm the only one!
Thats weird, I had done some research into and according to a lot of sources the old S10 5 speed was a t-5.... my uncle has a t-5 from an s10 in his '55 Chevy 3100 pickup.
As per directions here http://inliners.org/Jack/t5_page.html
and the tag numbers here also http://www.5speeds.com/t5/
SY2455
70's Veteran
If you will look again at http://inliners.org/Jack/t5_page.html you will find the only use for the T-5 trans in the S-10 were with a 2.8 V6, 2.5 L-4 or the 2.2 diesel. All of these use a diff bellhousing than the 4.3 and that why I said you have to find a bellhousing from a Astro or Safari van. I hope I helped you out as I doing the same thing as you. BTW I have been looking for a bellhousing for 2 years and counting.
jjorgensen52
Huh, I had not noticed that. Thanks for the heads up :lol: ... I suppose that changes my search a bit. Although, I was also under the impression that the T-5 shared a similar bolt pattern with older GM manulas and they could be interchanged ... maybe we should ask renz, his second Ty has a T-5 in it
jjorgensen52
SY2455 said:
I think it does use the same mounting as the older stuff. I have the stuff in the garage to check, but it to cold out there right now. However I want to use the hyd clutch in the swap. And there this.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ADD%2D712547&view=1&N=700+4294908216+4294908191+0&appfilter=1
I had looked at those. According to this site , the T-5 through 1991 (mine is a 1990) used the same bolt pattern and input shaft length as the muncie (350MT). Thus, it would appear that the bellhousing from a fullsize truck would work too, provided it's one with a bolt on bellhousing. I'm converting mine to internal hydraulic clutch using a Howe throwout bearing kit , so manual or hydraulic bellhousing doesn't matter to me
84TAVeRT
the borg warner t5 is basically a muncie t10 with an overdrive...
at least that is what i was told back on the firebird and camaro boards...
jjorgensen52
Did inventory today, the only parts I am missing are the catback system and clutch parts
2 small setbacks however
1. Trans is actually mechanical speedo right now (easy fix, just mildly irritating)
2. Much bigger irritant. The brand new Vortec marine longblock I bought on ebay seems to have turned into an L35 shortblock in the mail :dunno: :squint: :banghead: ... I have contacted the company that I purchased it from and hopefully this will all be sorted out soon (Their receipt even has the vortec casting numbers on it and they don't match the one I got :roll: )
Aside from that, going to round up the last few parts tomorrow, then I have to go back to school for 3 more finals and I will commence this for real on Weds next week. Hopefully we will have it running and driving before the new year :tup:
jjorgensen52
After a long and unsuccessful trip to the boneyard, I have a shifter but not a clutch pedal... dang those are hard to pull out :eek: .... Anyway, going to finals for the first half of this week and then going to try and round up the rest of the parts I need.
jjorgensen52
Alright, 4 hours and $40 later, I have a bell housing ($15 of which was a set of wrenches to get the one that I didn't have :banghead: )
It came out of a 76ish 2500 GMC truck... aluminum casting with the 5 1/8" bearing hole (the tranny is 4 3/4" but I don't think that matters... )
I will hopefully be dry fitting all this stuff tomorrow (as I have no flywheel and the motor is getting swapped)
Also, changing directions on the manifold. It was going to cost more than I wanted to spend to mate the two manifolds, so instead we are taking the old CMPI manifold and drilling it to the vortec pattern. Then doing a lot of porting
jjorgensen52
News: Killed it today. Not anywhere near as exciting as I would have liked.... tons of smoke... truck wouldn't rev past 3500 anyway. Pulled intake and both heads... a lot of crud in the cylinders and heavy carbon buildup, but no damage visible yet. Also, the crankcase was about 45% full with gasoline :lol:
jjorgensen52
Update:
Got the old tranny out today. Bellhousing and T-5 are in place. The shifter is going to come through the floor approx. 1/16" behind the original pivot point and about 1 1/2" below, so all will be well with the console location. Have to finish sandblasting the parts, cut the floor, modify the shifter plate and then install it all when I get the flywheel
jjorgensen52
Shifter is now located and installed... after having to weld it when I discovered that shifters are made from hardened steel and shatter when you heat and try to bend them :roll:
Will be hopefully installing the pedals and master cylinder today, then modding the console plate to accept the new shift boot.
jjorgensen52
Got the pedal bracket sandblasted, figured out exactly how I'm modding the console and got the threads and everything set for the install. Need to finish trimming the hole in the floor and add a front console bracket
jjorgensen52
MikeRenz said:
i don't believe any of this w/o some pics
One of these days I will get off my lazy butt and upload the pics from my camera ... today hopefully I will have the interior all done and will actually get you some :tup:
:stupid:
I am still waiting to see what type of contraption your going to mount on top of the throttle body this time. :)
jjorgensen52
dgoodhue said:
:stupid:
No such luck Dave ;) ... I've got enough crazyness on my hands making all these parts go together and look like they belong ... pictures uploading now
jjorgensen52
For the skeptics in the crowd:
Engine apart (I will upload the vid of it dying sometime later)
Tranny in the truck ( I apologize for the bad photos, hard to take without getting oily :roll: )
Custom welded S10 shifter ( we tried to bend it to the right shape, but it shattered)
6 speed Vette boot and knob over stock console plate in 4, 5, Reverse and neutral
Console plate opened up and screw mounts epoxyed in place (since sanded and painted, will have some installed pics later)
