Speed Pro C-Com software
1slownotch
All,
I was wondering if anyone here has used the FAST Classic software to operate the original Speed Pro C-Com Controller. I haven't had much luck getting the Speed Pro software loaded on my laptop and I have searched on here and see that a few people say they think it should work, but I didn't read anything set in stone. I downloaded the FAST C-Com WP software the other day and I was wanting a solid answer from someone who has done this successfully before. Thanks in advance for any help in this matter.:tup:
RealFastV6
@jb_and_his_coffee
Re: Speed Pro C-Com software
It will work fine. The Classic Fast was the FEL-PRO (Speed-Pro), just changed names when Comp bought it. I probably have the old DOS version kicking around somewhere but the FAST Windows version will work fine.
What's the version on the back of the box?
http://www.fuelairspark.com/news/fast/software/
(The one that says Grey Box ECU)
1madgumby
I was using a old HP with windows 95 or 98. Could not get it to load on vista or xp.
1slownotch
Thanks guys, I'm not sure of the version on the back of the box, as I haven't pulled the seat to check it yet. The comm cable and USB converter are hooked up and coiled behind the seat and I was going to do some data logging, but I had tried ever option that I knew of to load the speed pro software onto Windows 7, but even in compatibility mode, it will not run. I'm sure that there's someone out there that knows a quick way to make it work, but if it will work with FAST Classic WP, I'll just use it instead. Thanks for your help!:tup:
