Stock Intake Cleaning/Painting/Polishing
Aeroking
e.i.
Re: Stock Intake Cleaning/Painting/Polishing
mine
before
after
i did my upper plenum, my intake, and my cooler box.
i used aircraft stripper, then media blasted them, then primer, painted, and cleared them with Duplicolor engine enamel.
warmpancakes
ShuggsRR said:
Ohhh thats hot.
If you ever use this Phrase on this board again, I will start a petition to have you banned:rant:
It looks good though I would sand it smoother the Powdercoat it black
ShuggsRR
Whats wrong with saying something is hot? Cant use the old 1990s saying here? :dunno: :screwy: Or are the hotcakes jokes being taken personally now'? hehe :lol:
What do you mean sand it smoother? Take some sand paper and kill off some of the roughness?
warmpancakes
yep sand it a little smoother, The "thats hot" reminds me of Paris Hilton and I consider her to be the decline of modern socieity
ShuggsRR
What do you use to sand it?
Oh she says that? :rant: :no: :hang: :talk: :chair: :hissyfit:
warmpancakes
Idf hit it witk like 500 grit just to remove the big stuff
Robert Lone
MUTANT
93 typhoon said:
Man thats NICE how dos it feel and run? :tup:
Instant boost to 6 psi then the blower becomes dead-wieght. It's fun rowing through the gears w/ blower hangin' outta the hood. :tup:
Robert Lone
MUTANT
typhoon fever said:
howmuch fab work did u need to do to get that to bolt up??
One pulley, one tensioner out of a junk yard and two pieces of aluminum one for each side of the blower.
It's actually pretty simple. BTW, the way mine is built, it will fit any stock SyTy and allow you to keep everything but your hood.
typhoon fever
ty comming soooon
wow wish i knew that before i sold my blazer maybe could have done something around that
Robert Lone
MUTANT
Waller is about to do something similar to that on his beater.
turbodig
As an FYI, Eastwood makes a aluminum paint that looks very close to actual aluminum. Great for cleaning crusted aluminum parts up.
I tried the Duplicolor on my intake, but the aluminum is too shiny looking. The sucky clear they have is too yellow, also. Also, they have a product called cast-coat aluminum that's supposed to make parts look like cast iron. It makes them a greenish-gray. Ugh.
I wasn't gonna paint the transfer case, but it's sitting in the corner, whimpering at me...
Later,
I think this is the DupliColor that was mentioned. I remember it was the high heat ceramic coat stuff (silver/black label?) and pretty sure the brand was DupliColor. So far the paint is holding up very well and I see no signs of flaking or chipping. The thing I liked about it was although it looks textured, it's actually very smooth which maked cleaning a breeze.
btw... these are on the GT
ShuggsRR
Later,
I was just looking at at Eastwoods goodies the other day. I want to buy a couple cans of each.
WyoSyclone
Not even close to Mike's job.... but here's mine (have re-done the IC lines and EGR delete since this was taken). TB needs a lot of work... will probably go with a new one since I'm not happy with the throttle shaft play on this one.
SY2455
70's Veteran
Quote:
warmpancakes said:
Nothing on that truck is simple
This may be true, but his truck is a work of art and has most likely cause more accidents than anyone else on this forum from people taking a 2nd look while driving with that blower sticking out of the hood.:rotf: :tup:
