91Sleeper
Turbo Junky
Went to pick up the truck today (or so I thought) and the mechanic said the truck starts fine but has a high idle, so I started it up and it instanly shot up to 4k and I shut it off real quick. He was checking things out still as I left but still had not found the problem...I took him over the stock MAP because he said that he wanted to check it compared to the one on it, he also said the TPS was reading ok so that wasn't it, the throtle cable wasn't stuck and there wasn't any obvious vacum lines off anywhere...could the TB be stuck? . Anyone out there have any idea what could be causing this high idle? any input would be appreciated to help get her back home.
