Sy2932
aasltmike
Re: Sy2932
"Grade 10.9 (150,000 psi tensile strength) hex head bolts, M10-1.50X25mm front and M12-1.75X25mm rear, direct replacement for stock E12 (front) and E14 (rear) prop shaft bolts. includes Loctite 242 removable threadlocker. $20 by money order or paypal please. Paypal addy is syclone2932@gmail.com
I found that in an old post, if that helps...:tup:
bonesdmz
In Mother Russia Typhoon drives You!
Re: Sy2932
One set is required for the front shaft, right? Same for rear, or else?
Re: Sy2932
*POOF* Ok here I am, now what's you other two wishes :lol: ;)???
In the UK, POOF means something else :D
4 bolts at the front, 4 bolts at the rear. All provided in this kit.
"Grade 10.9 (150,000 psi tensile strength) hex head bolts, M10-1.50X25mm front and M12-1.75X25mm rear, direct replacement for stock E12 (front) and E14 (rear) prop shaft bolts. includes Loctite 242 removable threadlocker. $20 by money order or paypal please."
I've bought from Mike before - this kit is for someone else. I'm very happy with all my dealings with Mike.
:tup:
