SY2932's project page
SY2932
Administrator
Welp rather than posting up a separate thread for everything, I'll "compartmentalize" everything... Got to spend a full day plus in the shop today engraving some pieces parts.
First on the list was a differential cover made by Trick Flow for a member on here:
After securing it to the table, the dial indicator is used to get it in parallel as well was check it for trueness in height from left to right. It checked out within a few thousands of an inch so "buh bye" Trick Flow...
The four inch face mill makes quick work of cleaning it up for something more *exciting*.
Now that's what I'm talking about :)! Twenty seven minutes later the .0625 end mill has finished it's job. Engraved to a depth of .030". After I decked the top clean, the dial indicator was zeroed out on the top of the table. Then the cover was flipped over and the indicator was zeroed out at the lowest point. I knew that there was plenty of material on the back. Turns out that I had .325" thickness.
The owner of this cover is going to paint the script and desired a machined finish on the top that they were going to clear coat over. To aid in the paint department, the cover gets glass bead blasted to give the cover some "tooth" as they say after a good washing. All threaded holes are masked off to protect the threads.
To get the machined finish back after blasting, the cover gets a good cleaning and goes back into the machine for a fuzz cut of .002" (less than the thickness of a piece of paper or a hair) to clean it back up.
While that was getting cut, another part gets set up in the other machine. A HIGH profile owner on here wanted to have the horn button on his billet steering wheel engraved. The problem was that the flat on the top where the engraving would have been was quite small. The easiest way to address that problem was to just cut a new button:
This gave me plenty of time to work on other things like prepping stock or polishing parts before they were engraved. The finished OD on this button is the same as the original, 2.980" Time to engrave this with a .010" carbide engrave tip was two hours twenty seven minutes at a depth of .015". This tool is air powered and runs at 14,000-16,000 RPM.
In an effort to stand out from everyone else, a member requested the smallest turnbuckle that I have ever made:
In addition to being polished, it is engraved on every other side to a depth of .015". This was cut with the same tool that was used to cut the horn button above, the .010" carbide engrave tip. It takes twenty five minutes to cut each "typhoon" on this. Engrave time on this part alone is one hour and fifteen minutes. I drilled and tapped the center section for the stainless steel rod ends on the lathe. Mirror in the back ground to show the backside of turnbuckle.
The madness never stops and an engraved EGR block off plate is on the request list:
Tool is the .010 carbide engrave tip again and this only takes forty seven minutes to cut.
Just for "fun" I decided to make an additional horn button with just "GMC" in the center like the owner wanted originally. He's gonna be surprised when he gets his stuff back unless he sees this thread :lol:. I got to use a big cutter this time, a .047" end mill. That was a real time saver at fifteen minutes start to finish. The original button is at the top. It as well as the center of the steering wheel need to be lightly sanded and buffed due to scratches. These buttons just need to be hand polished and they will be done.
Today was a pretty productive day I'd say :)!
Sy-1177
Turbo Inside
Re: SY2932's project page
Mike's work is top notch for sure!!! Always awesome to see stuff that nobody else has! Very cool Mike! :tup:
I can't wait to see how them zr1's turn out!
1madgumby
Thanks A ton Mike for the (see below) !! I would like A horn button also!!
MC does some impressive work. Pics dont do it justice, holding one of his pieces in your hands really shows his craftsmanship.
1madgumby
Will be at the 2009 Nats, with the Ty. you can check it out. The hime joint is my new Alt./ belt adjustment.
1madgumby
Yes mike aka (metal god) made it for me, 78mm. center to center of eye's. looksbad ass, can't wait to get it on. even polished for me. :)
SY2932
Administrator
damn impressive right there, I dont even know what else to say... :lol:
Thanks, what's up with the CNC router? I keep waiting for you to turn out something soon yourself :)!
Chest Rockwell said:
Do you also carve center caps for my Corvette sawblades?
I have them drawn up in CAD, I just need to cut up a blank to test fit. Wanna be one of my product evaluators ;)?
Baythan said:
Man...that quarter looks like the real thing!
It wasn't worth the time to machine pennies, it took more time than they are worth :lol:.
Thanks for the props, I guess that I have a "fan club" of sorts :)!
Captain Morgan
Moderated User
Actually contemplating selling it and picking up a 4x8 table from Torchmate or something.
The sucker is just HUGE, which is nice, but I highly doubt Ill ever need to cut a 12' x 15' sheet of anything in my lifetime :lol:
Something smaller and cheaper would be more useful I think, plus Torchmate tables has adaptors for routers, plasma cutters and other things as well.
I just gotta find out how much this thing I got is worth and then find a buyer.
I been waiting for awhile to test these saw blade center caps.
hmmm
BigBadSmoosh
It would be fun to have something interested on the rear diff cover (for example: "see ya", "bye bye", FFFUUUUUU, etc.. )
wonder how much custom work would cost.
SY2932
Administrator
hmmm
Hiya Jeff :)! Hey amigo you're still on top of my short list! I'm still waiting for some original art from you :eh:? Where's the "fun" in sending you a blank center cap? That would be like getting and empty box of chocolates :lol:! Remember I was a rogue CAD/CAM guy and did your logo *thinking* that's that ya wanted. But it turned out that you wanted something else... I know that you know even with raster to vector, rendering geometry that can be machined can take many, many hours to do. Help me to help you :). Like I always say, "When you get something for free, you get what you pay for" ;).
SY2932
Administrator
Got a parcel with two pieces first of the week that I knocked out tonight in a few hours. All the vises are tied up at the moment in setups so I had to mount my spoil plate directly to the table. Dial indicator used to get it in parallel:
Part gets mounted up and once it's under way, I get the other part set up to run in the other mill. This differential cover is for a 8.5" rear end and has a recessed script unlike the 7.5" that I did last weekend. Tool of choice to clean this up is a .750" bull mill with a .0625 corner radius.
Cleaned up and ready for the tool offset, a .047" endmill.
While the differential cover is cutting, the other part finishes up. Time to engrave is forty two minutes with the .010" carbide engrave tip. Wow look! Someone else is making EGR block off plates that look like mine now! Oh wait, that IS one of mine sent back to me by the owner with his differential cover :lol:.
It takes thirty two minutes to engrave the differential cover. Afterwards in a carbon copy of last weeks cover, it gets cleaned, glass bead blasted, cleaned again and is then reset up and given a fuzz cut to clean it back up so that it has the machine marks on the face. This is done at the owners request...
That's a wrap for this week :)!
