Mikeysy15
Last night took out the truck for its first pass at Irwindale speedway . Stock motor, rpm stage 1 turbo kit , SM 3 inch downpipe , turbotweak 60lb injectors and chip , c12 fuel. 1st run on 16lbs of boost spiking 20lbs was 7.8 then turned it up on the 2nd run to 18psi spiking 23 and it went 7.67 at 89. Also picked up 2mphs . This is all on a manual boost controller with Stock selenoid disconnected. 60ft was 1.75 to 1.78. On my last run turned it up a little more and it spiked to 25 and got fuel cut . It happened right when I was about to hit 2nd gear on the shift . I think I need to turn the wastegate rod all the way out to help with the spiking . The last run for sure it would of gone 7.5 because the 60ft was 1.72 but the limp mode screwed me. Truck seems to run good with no knock on all runs . The most knock I saw was
0.8 in second gear which is normal . Spark advance on the race tune is 17 degrees on all runs . Let me know what your guys think . Oh ya forgot to mention truck weighs 3360 and 3600lbs with me in it . Let me know what you guys think .
