Testing the Waters, 86 Stang, High Dollar Parts
thumper_302
White Lighting
Testing the waters. This is a nice 86 Mustang with 12 passes on all new parts.
Before I list some of them I will give the bad news, the engine is out because it was blown. The car comes with a factory 302 as a replacement for the block and crank.It will need two pistons and a good set of rods.
Okay, now for the good stuff:
Car is painted 2000 prowler orange with bronze pearl but it does have one dent on the roof and some regular nicks and scratches but looks good.
Everything on the car is brand new.
Anyone interested in the car can call me to make an offer.
Thanks
Pete
The factory white inside and on the engine bay is clean, the whole car is very clean and in the pics you can see the 6 pt cage with the crosses behind the seat is also painted white.
Has a new c-4 with 3500 stall and JW ultrabell.
Full spool 8.8 rear with 410 gears, strange 33 spline axles, Moser girdle, welded tubes double anti sway bar coil overs.
5 point belts.
Have all the parts for the motor including BBK ceramic coated headers, 750 Holley DP carb, High Torque mini starter, new victor jr. alum heads and intake, high volume oil pump, roller cam and lifters and rockers, FMS chrome valve cover, electric water pump, 130 amp. altenator, new maunual rack. Has full exhaust with x-pipe with flow masters.Pro ratchet shifter,new white faced gauges, March serpentine belt system. has new gauges and tack, line locks.
Basically the engine/block needs to be rebuilt and put back in but everything else is ready to go.
Look at the pics and give me a call with any offers, 915-309-0703
Forgot some stuff, full MSD ignition (Distributor/wire/6AL), aluminum radiator, most of the engine parts are seen in the pics.
thumper_302
White Lighting
Re: Testing the Waters, 86 Stang, High Dollar Parts
Have gotten a few calls, thanks. The callers were pretty close on price so I will just give a ball park of what I am looking for.
Remember, the car comes with a 302 block and 302 crank, just needs a good set of rods and two pistions.
$6000.00 obo
Thanks, and don't be afriad to make an offer.
