Thermostat Question?
Will
I just finished servicing my radiator (Flush/Fill), and I also changed my thermostat. I was using a 160* therm. but lately its taking too long to heat up and the heater isn't blowing hot enough due to the cold weather (15-20*)
When I replaced my thermostat today I went with a 195* unit. The heater is blowing significantly hotter air, which is what I was aiming for. My question though, are there any significant side effects with running warmer I should be aware of? I know the knock is something to consider, and cooler is better in that regard.
I plan to go back to the 160* thermostat here in a couple of months when the weather gets warmer.
Any insight would be appreciated!
Will
TYPHOOL7
Post Hawk
195 180 160 all are good operating temps. yes with temp increases there is a knock issue, but not at 195 or below, over 200 that may become a problem for you but, Tom Dowds truck, featured in Streetrucks operates at 220 with 900 horsies.
Will
Yes, I beleive 195* was stock.
Thanks for the input guys, the truck is running good, and I can't tell any different at WOT, seems to run just fine.
Thanks 8)
adam92
Yep,195 is stock.I switched to a 180 2 years ago,and no problems,and still blows hot air for the heater.
