Todd Austinson 10 in 1 chip
After digging around on here, I got in touch with "runawayroger" who owned my truck from around 1998 to 2006. I emailed him and he told me my truck had a Todd Austinson 10 in 1 chip when he owned it and the controller was a little manual counter thing in the glove box. After looking closer I found it, I cannot believe I have not seen it before!
Can anyone give me any info on this set up??? How to use or adjust??? Setting meanings???
https://www.flickr.com/photos/syclone1453/33168103612/in/dateposted-public/
denny
Re: Todd Austinson 10 in 1 chip
Congratulations on purchasing the most advanced aftermarket chip available for the Syclone/Typhoon. This chip is actually a timing and boost controller, as well as a vehicle anti-theft system all in one package.
Installation: Installation is the same as described in the Multichip instructions. The only difference is the placement of the display/switching unit. This can be placed anywhere the user finds convenient in the vehicle, and can be secured using velcro tape if desired. The ribbon cable can be disconnected from inside the display/switching unit by removing the two bottom Phillips screws and lifting the bottom half of the enclosure. You will see the connector holding the ribbon cable which can be lifted and removed. This step will allow you to disconnect the display from the chip carrier in instances where installation requires the cable to be run though a small opening or drilled hole. Suggested locations are under the ashtray, under the side view mirror adjuster, or on top of the dash where it is easily accessible and viewable.
Operation: Once installed, operation is very straightforward. Press the push-button switch to toggle through the various programs. The display will indicate the current level of timing and boost, or any special settings contained in the chip, such as security (SEC) or valet (VAL). The timing is indicated by the first two digits, as T1, T2, or T3. The larger the number, the more advance in the program. T1 is a level similar to that of the stock calibration, and will be safe to use with 93 octane fuel at boost levels of 17psi and below on a stock vehicle. T2 has a couple more degrees of advance, throughout the rpm range and may require more than 93 octane, even at the lower boost levels. On vehicles with upgraded turbos and/or intercoolers, the lower boost levels of the T2 timing might be safe to run with 93 octane. This is up to the user to determine by monitoring knock, as it will vary from vehicle to vehicle. T3 has a couple more degrees advance than T2 and will require additional octane to run safely.
The boost level is indicated by the second 2 digits of the display, as the value in PSI (16, 17, 18, etc.) Note that the 24 psi programs will drop approximately 1 psi at WOT above 4800 rpms, to 23 psi. For those with stock turbos, keep in mind the limits of this turbo. The boost levels above 20 psi might not be reached due to the small flow characteristics of the stock unit. Also, due to its inefficiency above 20 psi, horsepower gains will probably be minimal above this level even if you are able to attain them.
The 2 position key switch is used to enable or disable program selection. With the key switch in the 12 O’clock, or CW, position, the push-button switch is active and all programs can be accessed. In the 9 O’clock, or CCW position, the push-button switch becomes inactive and the unit will remain in it’s last selected position until the key switch is back in the 12 O’clock or CW position and all programs can be accessed once again.
Programs can be selected or switched at any time the vehicle ignition is on. The display/switching unit requires power to operate and will not change programs without being powered up.
The best method of setting the security (SEC) program is to shut the vehicle off in whatever mode you were using, then turn the ignition on with engine off and toggle to the SEC program. Turn the ignition off again. Turn the keylock to the 9:00 O’clock position before leaving the vehicle to disable the unit. To start the engine again, turn the keylock to 12:00 O’clock, turn on the ignition with motor off, and toggle to the desired program. Vehicle will start in a normal manner at this point.
The Valet (VAL) program is a part throttle only program. It has a rpm limit of 4000, no intercooler pump operation, and significantly reduced timing. If an attempt is made to run at WOT (wide open throttle) the truck will sluggishly accelerate to 4000 rpms, then hit the rpm limit, shutting off the injectors. The truck will behave normally during all other operating conditions.
Programs are accessed sequentially in this order: SEC, VAL, T1-15, T1-16, T1-17, T1-18, T1-20, T1-22, T2-17, T2-18, T2-20, T2-22, T3-18, T3-20, T3-22, T3-24. Programs cannot be accessed in the reverse order, therefore it is best to shut off the engine when going from the higher timing programs to lower due to the fact that the SEC program must be accessed in order to get to these programs. However, if you can hit the pushbutton fast enough when reaching the SEC setting, you can get past the shutdown mode of the security program before it cuts off the engine. It is still recommended though that the engine be shut off first before toggling past the SEC program.
Ultimate Chip" History
Shortcomings of the Stock 2 Bar MAP Sensor
GM calibrated the stock Syclone motor to run 14-15 PSI boost, with a 2 Bar MAP sensor. They split the resolution of the MAP sensor into one Bar for vacuum (cruise conditions), and one Bar for Boost. This means after 15 PSI boost, the MAP sensor is maxed out and will continue to read the same reading (~200 KPa) even if the truck sees 20 or 30 PSI boost. Since boost = horsepower, you can see what a problem this presents. Early aftermarket chips just made the fuel extra rich at "15 PSI and above", but this is far from optimal. The ECM (and datalogs) still will not read anything over 15 PSI so you'll never know your peak boost on a run. It also makes it difficult to fuel properly and the further over 15 PSI you try to run, the more unusually rich it will need to be AT 15 PSI.
Solution: New Code to Support 3 Bar MAP Sensor
Brian Green devised a comprehensive solution around 1998. He reverse engineered the stock GM chip's Motorola "68HC11" code, and wrote new code recalibrating the chip for a new MAP sensor with 3 Bar of resolution (no small task, considering how many tables/values/routines rely upon the MAP sensor.) This allows the same 1 Bar for vacuum/cruising, but 2 Bars of resolution for boost. 2 Bars = ~30 PSI! With the new 3 Bar code, anyone running a stock '749 ECM can add a 3 Bar MAP sensor (original application: powering the factory boost gauge on the 1989 Pontiac Turbo Trans Am's stock 16.5 PSI "LC2" 3.8L Turbo V6), and then recalibrate their chips to provide accurate fueling/timing/datalogs up to 30 PSI!
Most of these chips were sold in a $350 package with a 16 position hardware chip selector designed & built by Todd Austinson, called the "Ultimate Chip". Each Ultimate actually contained 16 3 Bar chip calibrations, with the main difference being boost/timing/safety settings. In addition to being the first and only 3 Bar chips, they also contained what became the de facto standard aftermarket performance calibration (.BIN) for the Syclone/Typhoon:
Every modified SyTy running a stock ECM with a 3 Bar MAP sensor is running one of these calibrations or a derivative thereof.
Here's a list of the major changes vs. the factory chip:
Stock GM calibration vs. Ultimate Chip calibration
Feature Stock Ultimate
Maximum Boost supported 14.7 PSI (200 KPa) 29.4 PSI (300 KPa)
Typical WOT Timing 14* T1: 14*, T2: 16*, T3: 18*
Rev limiter 4800 RPM Stock Motor: 5450 RPM
Vortec Heads/Cam: 6300 RPM
Intercooler Pump Turn-On Temp 184*F Stock Motor: 66*F (always on)
Vortec Heads/Cam: Calibrated for electric fan control by default,
turn-on above 167*F, turn-off below 161*F
Compatible with DataMaster Yes Yes
With specs like these, there's every reason in the world to be running these chips compared to anything else! (such as the 2 Bar aftermarket chips like the ATR Pitbull, Kenne Bell, JET Performance, Hypertech etc.) Even a bone stock truck at 15 PSI boost would gain the benefit of being able to datalog boost spikes over 15 PSI.
50# Ultimate Chips
With the introduction of the PTE (Precision Turbo & Engine) custom stainless steel 3" downpipe and custom SyTy turbine housing around 2001, Syclones & Typhoons finally had a complete "bolt on" solution for a modified high boost truck. The stock 28# injectors are only good to low 12s/high 11s on 110+ race fuel (further with alcohol injection), so the PTE/Delphi 50# fuel injectors became part of the standard upgrade combination: PTE Turbo/Downpipe, 50# Injectors, and the new (in 2003) 50# Ultimate Chips tuned to tie it all together.
The 50# Injector series of Ultimate Chips feature major changes over the classic "Stock Injector" Ultimate, and were released in 3 series: Stock Motor, L35/ATR Cam, Vortec Heads/412 Cam. Instead of using the 16 hardware positions for different boost control settings, the program was split into 7 Street and 7 Strip calibrations, with the major difference being 14* WOT timing on the Street, and 17* on the Strip. Among the 7 programs, the only difference is WOT fueling (F77 table), with Program 1 being the leanest and Program 7 being the richest. Therefore, instead of being able to control boost from the driver's seat with the touch of a button, you can control WOT fueling. This is a nice feature for someone who's got a modified combo but doesn't have any chip tuning tools or skills.
denny
What’s a 3 bar chip and why is it better than a 2 bar chip?
To answer this question you must understand the ECM (your engine’s computer). Late model GM vehicles use one of 2 methods to determine the engine’s fueling needs: mass air flow or speed density. Mass air flow uses a sensor that actually measures the amount of air going into the engine, and from other data (engine speed, throttle position etc) can calculate the exact fueling needs. Speed density measures the manifold pressure, and its changes (along with engine speed and other related data) to meter fueling needs. On a naturally aspirated car (non supercharger/turbocharger) a 1 bar map sensor is needed, as the engine only operates in vacuum. The 1 bar map sensor can read from about 14.7psi vacuum (or negative pressure) to atmospheric pressure (0 psi). A 2 bar map sensor can read from 14.7psi vacuum to 14.7psi positive pressure (one bar vacuum, one bar pressure greater than atmospheric). In the same respect, a 3 bar map sensor reads from 14.7psi vacuum to 29.4psi positive pressure (one bar vacuum, two bar of boost pressure).
What are the disadvantages and advantages of each?
A mass air flow system can take into account different modifications (cam/heads etc) that are done to increase power, as the sensor can ‘see’ the additional air going into the engine and will add fuel as necessary. This is as long as the sensor is not maxed out, as mass air flow sensors have a limit to their readings. The speed density system is not as forgiving in its calibrations, as the calibration is usually set for a stock system. When major changes are performed on the engine, the computer reads the same manifold pressure levels as a stock engine, and the same amount of fuel is delivered, when more or less is really needed. So in this respect, a mass air flow system is better. It also does not use a restrictive sensor to meter air, as the mass air flow systems do. As I mentioned before, however, the mass air flow systems can be maxed out, so in a higher performance system, the speed density is the winner (and this is the main reason speed density is used on aftermarket ECM systems). In the syty application, however, this benefit did not exist.....
What does all this have to do with Syclones/Typhoons?
The SyTy’s use a speed density system, BUT the stock setup uses a 2 bar map sensor. So the ECM can only read up to 14.7psi of boost. So if the boost is raised above this amount, the ECM will not know the actual pressure, as the sensor is maxed out. Anything over 14.7psi would be read as 14.7psi by the computer. So fueling cannot be changed at higher boost, timing cannot be altered at higher boost levels, and boost control will not function efficiently (as the SyTy’s ECM controls boost also). So basically, for a person on a budget who wants a bit more performance out of their truck, it was a risky venture, as fueling wasn’t being compensated as the boost was turned up, timing would not be changed at higher boost levels, and the factory boost control was not operating as well as it could, all very dangerous situations, especially on vehicles so prone to detonate.
What’s the solution?
A chip calibrated for a 3 bar map sensor, to take advantage of the extended range of that sensor.
The advantages:
FUELING: A 3 bar chip now has the potential to add fueling at boost levels greater than 14.7psi. However, the stock setup is limited as the stock injectors are nearly maxed out (100% duty cycle). On the STG 3 bar chip,. the fueling is slightly leaner than stock, so a higher base fuel pressure can be run to deliver a bit more fuel at higher boost levels.
TIMING: The timing can be modified on a 3 bar chip at higher boost levels, for either safety or performance. On the STG Display chip, there are 3 levels of timing, for different performance levels (to be used with higher octane gas also). The levels are designated T1,T2,T3 (T3 most aggressive timing, T1 mild timing, stock like). Also, on each program, the timing is MUCH lower above the set boost level, in case of a boost spike or creep, the timing will drop significantly, hopefully enough that no damage would have been done.
BOOST CONTROL: The boost control on the 3 bar chips has the potential to control boost up to 30psi, BUT the stock wastegate is very undersized. If the stock wastegate is ported or if an upgraded integral is used on a larger turbo, boost control will be solid, with fine adjustments possible on the multi chip. So with this chip, there is no need for an aftermarket boost controller. No boost controller will work well with an improperly sized wastegate.
Special Features in the STG 3 bar chips:
Limit boost during first acceleration disabled,
Turns on intercooler pump when engine coolant reaches 60ºF thus eliminating the need and disadvantages of hard wiring the intercooler pump to run continuously.
RPM limit raised to 5400RPM,
Overboost fuel cut retained for safety reasons (2-3psi above boost level for that program),
EGR disabled in T3 (aggressive timing) programs, so as to not heat up intake (cruising to/from staging lanes),
Max knock retard raised (the stock amount of retard is limited to 12.66º, we raise this max to 18º).
Performance Features:
3 different timing curves, from mild to aggressive,
Several boost levels, from stock to 24psi.
Additional Ultimate Chip Features:
Key lockable switching feature which is nearly impossible to defeat. With the key removed, programs cannot be changed, including a "no start" setting which is an excellent security feature.
Valet setting with significant full throttle power reduction and a 4000RPM limit.
Dimensions on display/switching unit: 6"x4"x2".
Cable length of approximately 5 feet.
Notes:
The program selection will be displayed on the Ultimate Display chip, showing what timing level (T1,T2,T3), and what boost level (in PSI).As was mentioned above, speed density ECM’s usually need chip updates/reprogramming for every little modification. Our programs seem to work well on trucks with mild modifications (intercooler modifications, turbo upgrades). Trucks with wild modifications (high lift cams/ported heads/significantly larger turbos) will not run as well as a lightly modded truck using these programs. In the future, I hope we can offer programs for trucks with serious upgrades, and perhaps design some buildup plans that can utilize our programs, as the alternative (aftermarket ECM) is the only real solution right now, and is an expensive one.
Brian Green and I are finally ready to make the STG 3 bar multichips available. The chip will be available in two forms, unless you have purchased a 2 bar chip previously, then you have a third option which will be described below.
The first option is simply called the STG 3 Bar Multichip. It has 4 programs that can be selected with a small pushwheel microswitch, similar to the Todd A. 4-1 2 bar chip. This unit's first program is a reduced power program, with all stock limits in tact, reduced timing, and no intercooler pump operation. This could be thought of as a "valet" setting.
The second is a "street" program designed for 93 octane fuel, and will run 16 psi of boost if ecm boost control is used. The third is a "street/strip" program, running 18 psi of ecm controlled boost, and requiring greater than 93 octane. The fourth is a "strip" program runs 20 psi of ecm controlled boost, disables EGR function, and also requiring greater than 93 octane. The actual octane requirements will vary from truck to truck, and it is best to use a scan tool to determine safe levels.
As a rough rule of thumb, the "street/strip" should have at least 95 octane, and the "strip" 104 octane. All three performance programs will turn the intercooler pump on at a 60 degree engine coolant temperature, 5400 rpm limit, and no mph limit. Only the "valet" and "street" settings have programmed boost limits, both occurring at 18 psi. This allows the user to use an external boost controller without hitting any pre-programmed limits while operating the #3-4 settings. Price for this chip will be $200.
The second option is the most interesting. It is unofficially called the STG Ultimate Chip for now and is actually a timing/boost controller in one chip. It has a digital display/control unit that will indicate the selected timing and boost level, as well as a key operated lock-out to prevent setting changes when the key is removed. A pushbutton is used to select the programs when the unit is enabled by the key switch. There are 3 levels of timing and 6 levels of boost, from 16 -24 psi, that can be selected. In addition there is a valet and security setting which is nearly impossible to defeat due to the lock-out function of the display/control unit. There is really no way to defeat the lock out by any means other than breaking open the display/controller and re-wiring the internal circuits, requiring a good working knowledge of the system. Simply cutting the cable and getting "lucky" by shorting the correct wires together will only result in blowing the ECM B fuse, disabling the truck even further. In other words, it's a pretty good security system, minus a blaring alarm. Similar precautions will be needed as expressed above in determining safe octane levels for use with this chip. The high timing level can be run with 24 psi of boost, necessitating 107+ octane. I want to add that the higher boost settings (20+) might not be very usable with stock turbos due to their limited capacities. The 12.17 @ 112.1 that I ran last fall with my Typhoon was accomplished using the high timing program level with 22 psi of boost. I have been running a prototype version of this chip since last October. The high level timing selections also have the EGR disabled. Price for this chip will be $350.
The last option applies to those who already have one of the 2 bar multichips. These can be upgraded to a 3 bar chip by several methods. The first is to simply send the original back to me for reprogramming. You will get your chip returned with 4, 8, or 10 3 bar programs loaded, depending on what type of chip you have. The cost for this will be $50 for the new programs. The 4-1's will have the same programs as described for the STG Multichip. The 8-1's will get security, valet, 16 psi and 17 psi street, 18 and 20 psi street/strip, and 18 and 20 psi strip settings. The 10-1's will get an 18 psi street and 22 psi strip in addition to the 8-1 programs listed. The other option is to upgrade to the "Ultimate Chip" by returning your original to me plus $150.
All these new 3 bar chips will be easily upgradable due to hardware changes if and when software improvements are made. We will keep this cost at minimum to the 3 bar users. We are shooting for something in the ballpark of $25 for these upgrades.
The STG Multichip is avalable now and can be ordered through Brian Green. The "Ultimate" will be available in about 3-4 weeks, but if you want one of these I'd like you to contact Brian (or me if this will be an upgrade) now so that he can relay to me how many I need to make. I'm sure Brian will have something to add to this so stay tuned.
Todd Austinson
'92 Ty #1548
12.17 @ 112.1
STG
To upgrade to a 3 bar chip, we will need a 3 bar map sensor right?
Yes. GM/ AC Delco part number 1604-0749 - sensor assembly.
As far as upgrades go, I am working on having a program for 44lb injectors for stock engined trucks. This will be ideal for those running larger turbos and big boost, trying to squeeze all they can out of the stock engine. Hopefully this program will be available in the near future, with other programs to follow probably (44lb chips for cammed trucks, possibly 50lb and 55lb programs also). For those of you skeptical of a 44lb injector chip program, I'm more impressed with their performance than stock injectors. I got a smoother idle/off idle than with stockers, with great throttle response and pulsewidth control, just have to dial it in now at WOT/boost. So anyway..stay tuned for that.
If you have questions, concerns, or want to order one of the chips, email me with "STG 3 bar chips" in the subject.
For those of you interested in the display, I don't have much information on it yet, as Todd is still working on it and changing it. When we have it ready, we'll probably have a webpage with pics and description of it.
Thanks
Brian Green
syclone 160
STG Racing
Some things I inadvertently omitted while writing the initial message. That's what you get when you try to write a lengthy note while holding 2-3 instant message conversations.
First of all, it has been pointed out that I should have mentioned that a GM 3 bar MAP sensor is needed (replacing the stock 2 bar) to run these chips.
The display/control unit will be shown shortly on a web site, but this hasn't been completed yet. The display will indicate which particular program is being executed, e.g., security, valet, timing, and boost level. As you toggle through the selections the display will update. The best way I can describe the size and appearance of the display/controller is that it will look like a G-tech performance meter or small radar detector.
Look for updates on the soon to be web site, with more specifics on the 3 bar functions and advantages.
Todd
denny
the STG 10 in 1 chip I know of has a four characters digital display, never say one like what you have.
display like this.
T1 F1
T1 F2
T2 F1
etc
Is this chip system out dated???
Yes, very dated. Neither Todd or BG have worked on the Ultimate chip or have been active in the community for years now.
Today's plug and play chip is TurboTweak. There are options to buy it with a single setting or dual setting (street/strip). It is very reasonably priced and has received the praise of many owners including myself.
Looking at your pictures that is an earlier 10n1 chip. It doesn't even appear to be a 3bar chip. Yes it is outdated.
That's what I was afraid of. Anyone know of anyone near Greensboro. NC that knows anything about these trucks I could take the truck to, to take a look at it and maybe do some minor tuning????
graham1524
Well-known member
Where are you at in Greensboro? I'm around Burlington
Sywisconsin414
I have this and need help with the color code. Long story short I don't have the pushwheel and want to set this tune for a safe tune and daily drive the truck. I have the ohms resistors hooked to black and need help with what wires get hooked up for like I said a safe tune with 93 octane being the main concern. Tia
Sywisconsin414
gmemony2
Do you want to keep this chip for any reason? It may be easier to go to something "newer" at this point and let it go.
DaveP's Ghost
Well-known member
I'm just looking for info on the exact wiring diagram for the 5 wire pig tail wired into the eprom.
I have an ECM / 10 in 1 combination I took out of a running truck as an assembled unit. The ribbon cable disappears into the ECM. I've never looked in there. I can take it apart and take pics, if you think they would help.
