jdeangelis
First, I don't beat the truck; Tracked once.
At about 80k I started to get a bad shutter when the truck was in 2nd or higher gear when I was at low RPMs and starting to slowly accelerate. Guy told me my TC was bad. Replaced TC. Seemed to do the trick. About 12 months later the shuttering started to come back. If I run the truck in Drive, not Overdrive, I avoid the problem. Seems to happen at 1500RPMs.
Did the new TC cover-up a some other transmission problem? Forgive me for my ignorance, is there something else within the transmission that causing it shift early, leaving me to low in a gear?
