Truck Dies Randomly
neildemo
Administrator
Well My patience has run out on my Syclone. I have changed Plugs, Rotor, Distributor set timing to 0, with Brown wire off. When I give it gas it falls on itself feels like something is holding it back. Check fuel Pressure its at 55 when idel. I have a ATR pitbull chip in it. Truck will usually die when i pull up to a light. Any suggestions would be deeply appreciated. Have spring fever and would love to drive it this weekend. Thanks again. Checked all hoses to there all fine. If I leave the brown wire disconnected I dont think the truck will die havent thoroughly tested though. I am willing to paypal someone for some guidence, As there are no qualified technicians around here :(
Sportmachines
Re: Truck Dies Randomly
First things that come to mind is pull that chip out of there and put a stock one in and see if theres a difference. Also, if its a stock truck, the FP seems a bit high. Where is the idle at when its sitting?
cloned
First thing I would check is the IAC valve. Take it out and clean it also clean the throttle body and ports for the IAC.
neildemo
Administrator
Idle is at 800-900 rpm fuel pressure is adjusted to 42 psi.
Will check IAC valve and clean it.Also Clean the throttle body Thanks for the info.
leroy
I found one truck that had a bad turbo to intercooler hose. The inner part of the hose would collapse when vacuum was high and stall the engine.
Jim
BoostedSUV
Fuel pressure sounds way to high. What injectors are you running? Are you adjusting it with the vac line off?
