True Trac rear end ??
SY2455
70's Veteran
NecroWolf
lost marbles member
Re: True Trac rear end ??
i don't see why it wouldn't fit if it was a regular jimmy and not a zr2 or anything
Nope. It's suppose to be similar to a Zexel Torsen LSD. It doesn't provide 100% lockup, from what I've read.
sy2675
He Saved the Pimp'n Game!
I Was Going To Use The True Trac In My Sy But It Was Back Ordered Thru Summit, So I Went With Carbon Posi Unit, I'd Def Snatch It Up And Use It Or Sell It.
'JustDreamin'
Dream: 6LV8 Turbo Bravada
The TrueTrac is a niece piece.
Def check gear ratios, since somebody obviously had it put in, it's possible the ratios were swapped (front and rear) to something other than what the glovebox plate would indicate.
It certainly is a better diff than the factory Gov-Loc which isn't a limited slip. More of a limited spin, by design.
'JustDreamin'
sly dvl
Ya, it's got a Turbo
DaveP6999 said:
The biggest head ache you're going to run into is the rear wheel sensors, if you're still running ABS. The 93 doesn't have any.
Not to hijack this thread but reading this reply reminded me of a question I had.
Do the SyTy's have separate wheel speed sensors on each rear wheel, as opposed to one sensor at the output of the trans. like most GM trucks?
SY2455
70's Veteran
Yes you are correct each wheel has its own sensor:tdown: .
