TRW pistons and compression ratio
92Ty#1524
Im running TRW L-2441 pistons with a .030 overbore.
Read something on http://syty.org/old/modlist.html regarding the need to "skim" the pistons to bring the compression ratio back to stock "especially with .030 over..".
Has anyone had to do this? I could use some specifics before I take them to a machinist (if need be).
jwaller
Evil Genius/SyTy Guru
L24421 should be close to the raight ratio. esp if you havent zero decked your block. I wouldnt worry about it...
the highest you might see is 8.3:1
GEN3Typhoon
I had nearly the same setup and if I remember correctly I got 8.45:1 when I figured it.
Not a significant difference...
Lynn D. Brown
TRW's
TRW's
No big deal if the CR went up a little bit, just lower the boost accordingly. I have Vortecs and I guess that puts my CR somewhere around 9/1. Be damned if I'm going to do a bunch of work to LOWER the CR back down. Cylinder pressure is cylinder pressure, however U get it.
But let's not get into that endless thread again.
Sy769
Re: TRW's
Re: TRW's
Cylinder pressure is not just cylinder pressure. Lower static CR with higher boost will make more WOT power at the sacrifice of off boost torque.
Sorry if I start a endless thread :D
Lynn D. Brown
Boost vs CR, again
Boost vs CR, again
OK, sounds good Patrick. So, if Ur a heavy racer always pushing 4 more, more boost may be better, but if U R a street-strip kinda guy, who will be happy to be in the 11's and stop there, I'd go the other way. I just don't like humongous boost and all the problems that come with it.
