tuning on ebay?
TT350
Manufacturer
Re: tuning on ebay?
Nothing like a new guy trying to throw
another log on the fading fire and what does
he get, a swift kick in the nuts and trip under
the bus.
Oh by the way welcome to SYTY.net
:fan:
jabberwalk
Re: tuning on ebay?
cloneman315 said:
Patience, Patience!
First off all Thanks to Ashman for hooking me up with a Moates adapter!
I just got back from a 72 mile ride and I have to give it a :tdown:
Idling:
The truck starts fine and idles well, but there is a smell similar to a car running very rich. No smoke of soot from the pipe, but letting it idle for a minute- you can really smell it.
Driving:
First of all the first boost limit is still in place. I specifically asked for it to be removed. Driving normally, there is no difference between the Pitbull and this one. I can tell the difference when I shift neutral and let the truck coast. The pitbull drops the rpms very low and the truck struggles to stay running. It has stalled a few times. The Top line chip does not do this.
Wide open throttle is where I have concerns. The first time I stomped it from a 30 mph roll, the engine started bucking and cutting up at around 3k rpms. I pulled over and switched chips back to the pitbull and repeated the run with no bucking at all. I had a full tank of gas so this was not fuel slosh. I pulled over and put the Top Line chip back. I repeated the test and had the same problem. That ended the acceleration tests for me. I am not comfortable running the chip at the track, so I am sending it to Ashman to let him read it.
Sorry guys, the hype is just that- hype.
Jimmy
Banned
Re: tuning on ebay?
jabberwalk said:
Patience, Patience!
Idling:
Driving:
Let me ask you this Jason,what did you expect from a (sic) no-it-all Texas baby raper? :roll:
Also:Why in the hell are YOU evaluating chips when you can't even keep a stoopid tranny line connected? :rocol:
jabberwalk
Re: tuning on ebay?
Hey- lets try not acting like dicks today!
Flyin Ryan
hated cuz he drives fords
Re: tuning on ebay?
H-TOWN-TYPHOON said:
Did you use datamaster to record/validate your findings?
You should have deff data logged every aspect of that chip especially before stomping on it.. still interested on how it compares to the cheesy shitty chips like hypertech, magnum, etc so hopefully man checks er out good
Daron
Re: tuning on ebay?
Man I guess I really had this dood all wrong. He actually sent a chip that runs and idles?
I sincerely hope nothing ill happened to your motor when you got on it.
jabberwalk
Re: tuning on ebay?
Don't have a datamaster. I am going for a subjective comparison. I'll get it to ashman so he can read the Bin. I drove for 30 miles on the highway and back roads before getting on it.
ashman
Re: tuning on ebay?
when jabber gets finished testing and sends me the chip, i'll read it and compare it to the stocker. should be easy enough to see what the magic is.
slamdxterra
Re: tuning on ebay?
i just read this whole thread start to beginning and i couldnt help but laugh! We all knew what this chip would do! He just bought software for generic tuning. Probably works fine on a stock N/A vehicle. Well you guys gave him a chance and we all knew what the outcome was gonna be! NO MEANS NO!!!
Jimmy
Banned
Re: tuning on ebay?
It was MUCH better live,trust me. :haha:
jabberwalk
Re: tuning on ebay?
The chip has been sent off so some syty experts who have read it. Maybe they will chime in with what they found.
Flyin Ryan
Re: tuning on ebay?
hope so.. cuz even if the chip was a waste i'd still like to hear about it
ashman
Re: tuning on ebay?
maybe Dig or Jeff can give some insight, as they have seen the code. I've looked at the code also and was suprised by the number of changes made from the stock chip. two items i noted was an increase in timing, across the board, of 2.11 degrees and a significant increase in desired boost pressure.
Jimmy
Banned
Re: tuning on ebay?
Timing and boost huh. Wonder if he added any fuel?
ashman
Re: tuning on ebay?
only a handful of fueling changes in the upper RPM (=>5600) of 'Base VE -vs- RPM VE ADDER (F30)' and leveled 'PE AFR Vs RPM (F61)' to 12.6
Re: tuning on ebay?
I wonder if he even changed or noticed the 4800 rpm fuel cut off :rotf:
MRKING
New Parts for Old Trucks
Re: tuning on ebay?
I am still laughing but I got to know , are you guys seriously evaluating his chip like you expect positive results ?
