I recently picked up both the coolant and oil lines for the stock turbo from RPM and managed to get both the upper Coolant line and oil drain line on without a snag. Started working on the lower coolant line and after pulling the starter I managed to get the old line off, In the process i must have damaged the threads on the brass fitting on the side of the block and for the life of me couldn't get the new fitting to thread into it. Just wanted to know if the fitting on the side of the block is removable or not? Seems to be in there fairly good and wasn't sure if I could replace it or If I'm gonna need to re thread it. Any help/advice would be greatly appreciated. :tup:
I'm referring to #7 in the picture
