Urgent Question!
Schwimms
I'm going to bid on some wheels, but im not too sure if the offsets are right. Heres the specs:
8.5x18, 38mm for front and 9.5x18, 19mm for the rear
I used the wheel calculator and it looked fine. I'm not to sure how it works though. I need a quick response so I can bid. Help Please.
Ozrein
BC Syclone
Re: Urgent Question!
Looks like your front will be 9mm out from where the stock wheels sit and 3mm in. And your rears will be 13mm out front stock and 25mm in. Should work fine as long as you dont mind the wheels sticking out a little more than stock. You should have plenty of room in the rear for the extra 25mm in.
Syclone#1992
SyTy.net Moderator
Why do you feel the need to post in two different forums, especially after I deleted your last double post from the Lounge? This place is too small to have double and triple posts! Please post in one forum (the correct one) and one forum only (Wheels and Tires), it keeps the place more enjoyable, organized and more effecient!
Thank you,
Schwimms
It was urgent no one comes to the wheel forum, I had to get info b4 bidding was done. Sorry I should have posted in other forum first.
Ozrein
BC Syclone
It does seem to me that just as many people come to this section as they do other sections. It's just that there tends to be more posting in the general section as compared to here.
