Hi guys,
I've been trying to start my Syclone this week but have a bit of a snag with the starter.
When I turn the key, it engages and the motor turns and then after a couple of seconds, there is a massive bang and it stops turning. I looked under the truck when it was turning and the flexplate seems chewed up at one spot. I've tried shimming the starter and that seemed to help but sure enough, BANG. I can't do much with this issue so... A little history.
I have the vortec block flexplate and ordered a starter from an Astro van thinking that would work. I know the offset is slightly off so I plan to take it off later and compare it with the original one. I thought I did at the time.
I saw that some people mentioned elongating the starter motor holes to make this work but also a thread where E-Rue ended up using a balance shaft starter motor. Who has done the bolt holes mod and how did you do it please?
Can I make the stocker work or is that not possible? Only a small part of the flexplate is chewed up so if it were the teeth on the starter, I'd have thought that all of them would be messed up.
I need to pull it anyway as the ground to the starter is far too close to the DP but I'd like to know what to put back in the truck.
Hope you've had a great weeked!
Thanks in advance,
Mark
Thanks in advance,
Mark
