Vortec Heads and Exhaust Manifolds
eficonnection
Today I mocked up the SyTy exhaust manifolds on a set of Vortec heads and found that the bolt pattern did not match. Somehow I overlooked this while reading about the Vortec head swap. Can someone please fill me in on how this is commonly addressed?
RealFastV6
@jb_and_his_coffee
Re: Vortec Heads and Exhaust Manifolds
The bolt pattern matches fine, although you may need a manifold spreader to get them on since the manifolds have a tendency to warp.
http://www.amazon.com/Lisle-13000-Manifold-Spreader-Chevrolet/dp/B0009OR94W
What Vortec castings are you using?
Black Knight
I Glow Therefore I am
x2, never had any trouble with mine, but I did have to use the spreader.
fivetodrive
CRISPY
I heat them up in a 500 degree oven and bolt in the outside holes real quick! Works perfect and you dont have to wait for a spreader!
Use a torch as well as the spreader. Can be a pain in the ass but they do line up eventually.
eficonnection
Thanks guys. Here are a few pics.
alwayscode390
pppssssshhhhhtttttttttttt
OUCH, I didnt know they werent an easy bolt up either ... good to know ---
alwayscode390
Im guessing its better to use the spreader BEFORE uninstalling your manifolds? ---
Don W.
Only because I have access to a fully equipped welding shop did I heat mine cherry red, spread them, then allow to cool with spreader in place did mine then fit without the spreader. Worked well but I was lucky.
You pics show the same misalignment I had.
I would suggest bolting up the close pair then spreading the far pair. That way you can watch and only go as far as absolutely necessary.
My manifolds easily line up. I learned along time ago not leave the manifolds unbolted & laying around so you don't need to use manifold spreaders.
ItsMyTy
Life is beter at 25 PSI
Heat and install if you can. Enlarge the outside holes if necessary.
I have seen people crack manifolds using the spreader properly. I would only use a spreader if absolutely necessary.
wildphil
I Love My Ty's
I keep a spare set of heads just to bolt the manifolds onto. When they are removed from my engine. That keeps the bolt holes from moving.
