mrweelr
I need some help guys. My RPM motor has Vortec heads and ported/polished modified stock intake and the passenger side FelPro gasket is leaking oil after less than 100 miles :-( I torqued all ARP fasteners to correct specs and in the right order and it's leaking along the passenger side gasket in two places. Oil eventually pools in the intake well near the front. The driver's side is bone dry and the motor runs fine. What bothers me is I have no clue why this thing is leaking and don't feel like pulling the intake until I have a good idea as to what the cause could be. Both valve covers vent directly to a Moroso catch can and I verified there is no restriction, so I don't think it's a crankcase pressure issue. There is a small gap/opening close to the area that's leaking that I've circled in the pic; is that normal with the Vortecs? I removed that little allen plug and resealed it, but I verified for certain that's not what's leaking. Mike suggested I try some "Right Stuff" sealant which I picked up at Autozone, but in theory I shouldn't need to use anything for this to seal properly other than new gaskets, right? Should I try thicker gaskets or something? Here are some pics. Let me know what you guys suggest.
