water cooled turbo plumbing question
Syty84
I have a stockfish turbo, is it possible to reverse the water plumbing connections on the turbo, for instance the port on the left side is the current feed/flow and the right side goes to the return, 2nd question can I run a line from the water pump directly to the turbo and return it to the intake manifold, sorry if this is confusing.
Damian
Re: water cooled turbo plumbing question
It doesn't matter which way the water flows through the turbo.
Syty84
Thanks for the reply, also do you know if I can run my feed line to the turbo from the water pump port and use the return at the intake manifold that use to feed the turbo?
Damian
I don't know how the coolant ports flow, so no idea. Just run them the stock way.
I believe that the water pump fitting is on the suction side, so it would draw the water from the intake side after it has been heated by the engine.
