Let me be the first to warn you about something else, because this is EXACTLY why my typhoon isnt moving right now.
Along with hard start in the mornings and very bad idle, I started having cutout while driving just this past week... foot on the pedal and the truck would cutout and "pulse" and cutout.... until i took my foot off the gas...
i would sometimes get back throttle repsonse, sometimes it would keep pulsing on me.
No codes, but i changed the fuel filter first...when the cutout didnt stop i swapped the TPS, MAP and new wires... still couldnt get the truck down the road.
Finally got it hooked up on diacom and watched as my 02 volts dropped down to almost nothing when in the throttle... a sign of the truck leaning out and not getting fuel... and the final knife in the back that i have a fuel pump going down.
** WHY HAVING DIACOM AND DATAMASTER IS IMPORTANT TO DIAGNOS **
If your truck has decently high mileage, you may want to consider changing your pump and upgrading to a walbro 255.
If you have done so already, you may have a clog AFTER the fuel filter. If thats the case, you may want to consider running a fuel cleaner or additive such as xylene to help move crud out of the lines and injectors.
