Which timing mark is right
racinreaper
I just rotated the engine a few times with #1 plug out... noticed where the compression was while watching the rotor.. then got it close and turned it by hand untill the rotor was on #1 and the first mark on the balancer was lined up at 0.. the problem I can't figure out is that I am a new owner and from what I have read in the Hayes manual on 4.3's it says that you should use the second mark on the balancer instead of the first. SO which mark do I use.. could a prior owner have pulled the dist and put back on the wrong mark?,,, I'm confused and dont want to mess it up..
scottKP
Timing Marks
Timing Marks
We just did the same thing tonight and we went to the second mark. Whether its right or not????????
sytyguy
Moderated User
Below is a picture of a balancer with a single timing mark. You should be able to measure based off the woodruff key to see which one is right (I'll do it myself in the morning).
HTHs
Hood
