Will 2006 rims fit? if not is there any changes that might make them work? got A line on some not sure if they will work on A 92 ty. with A 2 inch. drop off set or anything else.
I think you'll need spacers on the rear for sure, maybe in the front too. I believe the new ones use a 50 &/or 70 mm offset. Do the rims still have the Corvette issued tires on them? There might be an issue there with the rolling diameter of the tires since they use 19 & 20" configuartion, it cant be any greater than 1%?. You can go to tirerack.com and spec the exact tire you have size, etc. I run 1994 Corvette sawblades on mine with the same tires from the Corvette and no spacers.
Here's a link: http://www.sytyarchives.com/howto/viewarticle.php?article_name=wheel_tech.php&dir=exterior
